Big block conversion....
Old Jul 1, 2002 | 12:05 AM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
Default Big block conversion....
What does it take to put a 454 into a 74 Vette w/ 350? Anything I should know about before hand?
Thanks alot!
Old Jul 1, 2002 | 12:44 AM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
Default Re: Big block conversion.... (88'Cubka)
no one has swapped a big block into a c3? :D
Old Jul 1, 2002 | 12:58 AM
Steve Straus's Avatar
Steve Straus
Quite a few of us have. I'd do a search on it, you'll find plenty of topics.
Old Jul 3, 2002 | 04:24 PM
norvalwilhelm's Avatar
norvalwilhelm
The swap itself is very easy, the accessories and pulleys can be a problem. The stock small block motor mounts, transmission and ignition work fine. Add a set of headers and the motor bolts right in. If you use a long water pump the donor engine power steering brakets and alternator mount can be used. The stock rad is marginal but you need electric fans. The mechanical fan will not work with a long pump. If you use the short pump you will have problems finding the proper pulleys and mounting brakets. No wrecking yard here. Special order, big dollar. I went the long water pump route at first then switch later to the short and made my own mounting brakets and pulleys. A very easy swap. Shane just did it, talk to him.
Old Jul 3, 2002 | 05:02 PM
Wardog's Avatar
Wardog
Default Re: Big block conversion.... (norvalwilhelm)
You also need to watch out for cooling. Put in a higher capacity radiator while you have it all out of the car. Get those little foam heat shield pieces that wedge between the firewall and the bell housing. You will be generating much more heat with that big block!
Old Jul 3, 2002 | 06:24 PM
Steve Straus
You can get a set of March pulleys and brackets for about $700-$1000 depending on what kind and how many you need. I only have an alternator and power-nothing, so it was easy for me.
Steve
Old Jul 3, 2002 | 07:26 PM
467-Ratman's Avatar
467-Ratman
I finished my conversion the first of May, it was a lot of work, but not too bad! The results are FANTASTIC!!!! The power to weight is awesome, I have really enjoyed my car more this year than ever. If you have specific questions let us know on the forum, many people are here to help you. I guarantee after your finished you will have a perma smile!! Good luck!
Old Jul 3, 2002 | 08:27 PM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
thx alot guys and if i fall into any problems, ill be sure to post thx again
To Big block conversion....
