Harbor Freight 69512
Old Aug 25, 2013 | 01:31 AM
Kalvin's Avatar
Kalvin
Default Harbor Freight 69512
Has anyone used this cherry picker on their C3? I'm concerned if it will have enough reach?
Old Aug 25, 2013 | 04:37 AM
Zedred's Avatar
Zedred
It will work, best to go in from the side, instead of the front, if your pulling a big block you might want to pull the heads off first.
Richard
Old Aug 25, 2013 | 07:32 AM
Jig A Low's Avatar
Jig A Low
thats the one I have, it will work but won't reach from the nose of the car, you have to go in from the side. I would get a set of wheel dollies and put the car on them first, that way when you lift the motor you can just push the car out from under it sideways.
I also used it to pull the body off the frame as well. I've had one for years and have pulled many motors with it, it's just now starting to have issues with the hydraulic pump for the lift cylinder where it takes ALOT of pumps to lift it.
Old Aug 25, 2013 | 09:25 AM
whitehause's Avatar
whitehause
I have one too...as everyone else said, go from the side.
I will say if you plan on using a leveler DO NOT buy the one they have there!!!!!! I used it one time and as soon as I got some angle on it the rear plate that holds the chains snapped! Luckily it was past the fender and over the engine bay and the front chains held. The trans ( a 4sp M21) was attached and was almost in position, so the tail only dropped few inches till it hit the wood blocks I had on the jack.
The picker worked fine though.
Old Aug 25, 2013 | 10:07 AM
mrvette's Avatar
mrvette
I got really llllllucky back in '97, went to rent a hook, and so found a rental place being bought out, and so bought a hook that knocks down to a little cart with the 5' steel storing vertically, sets on about 2' sq of garage space, stupid thing can lift an entire SUV.....150 bux, I spent....goes in on the nose of my 72 and not even close....
Old Aug 25, 2013 | 10:18 AM
MrJlr's Avatar
MrJlr
$120 on CL
And it folds up
Old Aug 25, 2013 | 02:36 PM
Super6's Avatar
Super6
Richard
Definitely go in from the side. You can leave the hood on (not disturb the hood alignment) and not touch the radiator. You can leave the heads on, even with a big block. Unfortunately, I know. I've been practicing...427=> 468 => 540.
Old Aug 25, 2013 | 02:49 PM
Kalvin's Avatar
Kalvin
Default Coupon Code 83087728
Thanks for the replies. I saw a coupon on Ebay for this crane for $99.95 and I knew I could probably find the code # with a little searching. 83087728. Of course my HF didn't have one in stock and wouldn't have any in until after the coupon expired so I just ordered it online for only an extra $6.99 Fedex shipping. That's a win win in my book! Normally this crane is $229.95 and it's sale price is $184.95 so $99 is a pretty good deal if anybody else needs one.
Old Aug 25, 2013 | 10:00 PM
BlackC3vette's Avatar
BlackC3vette
HF has two models of load levelers, a 3/4 ton and a 2 ton, which one do you have (that failed)?
Old Aug 25, 2013 | 10:20 PM
whitehause's Avatar
whitehause
The 1500 lb'er. I understand it a HF item, but I didn't expect it to break with half the rated load on it.
Old Aug 25, 2013 | 11:49 PM
BlackC3vette
I am so happy I put that one back up the shelf!
Old Aug 27, 2013 | 10:53 AM
TWINRAY's Avatar
TWINRAY
They have in the past 2 years really boosted the prices of the cranes. I bought the 2 ton unit with a Super coupon and remember getting a real good deal. Delivery to the house was something like $16 wile other places wanted $100 bucks or so. It helped that I had the whole front end off.
Old Aug 27, 2013 | 11:10 AM
MrJlr's Avatar
MrJlr
That looks REAL nice
Old Aug 27, 2013 | 01:37 PM
cv67's Avatar
cv67
St. Jude Donor '05
I have the same exact one and have lifted the body off my Camino off/on numerous times no problems. Its actually (jinks!) decent. The fact it folds up makes it a keeper not too heavy either .
Old Aug 27, 2013 | 02:03 PM
Planbmatt1's Avatar
Planbmatt1
i got the 2ton one from freight harbor for $99
Old Aug 27, 2013 | 02:09 PM
Shark Racer's Avatar
Shark Racer
Boo-hoo.
Old Aug 27, 2013 | 03:12 PM
BEJ's Avatar
BEJ
Originally Posted by MrJlr
$120 on CL
And it folds up
I have the Big Red version of the same crane. The nice thing about it is that, since you have to go in from the side, the wheels pivot allowing you to move it sideways. I used it to install my engine and trans as one unit, by myself.
Bryan
Old Aug 27, 2013 | 05:57 PM
tixeon's Avatar
tixeon
I pulled mine with a borrowed 1 ton unit. I bought a HF 2 ton unit when it was time to go back in. World of difference, buy the 2 ton unit. Or borrow one. The extra reach made it a lot less stressful and the unit is solid. Dave
To Harbor Freight 69512
