Exhaust recommendations?
Old Aug 26, 2013 | 04:08 PM
Zapawaf's Avatar
Zapawaf
Default Exhaust recommendations?
Hey guys, it's been a while, but I'm finally ready to pick up an exhaust system for my 79 Vette!
Brand new 350 crate in it and a set of Hedman Headers
http://www.jegs.com/i/Hedman/500/68306/10002/-1
I talked to Jegs who I bought the motor and headers from, and they said they had nothing that would fit directly but they'd have something universal that could be made to fit. He recommended having a custom exhaust shop build something for it instead.
A family friend who has a collection of Corvettes suggested 21/2 inch pipes and 40 series flow masters. Called up a shop and they said it would run around the $500 price range if they had to do the flanges. I have to be honest I don't know much about cars. Doing the motor swap, suspension, clutch, ect. was all learn as you go from family/friends and a lot of help from you guys on here. So here I am seeking your expertise!
My other question, would the shop typically include the cats or is that something I should look into?
Old Aug 26, 2013 | 05:27 PM
Scott Marzahl's Avatar
Scott Marzahl
Personally I would not use those 40 series flowmasters, lots of drone and they may drive you nuts in the Corvette cabin with how loud they are. Question is do you have to install cats for your state. They will be more money and hinder the performance, granted there are hi flow cats on the market. Personally a 2 1/2" pipe system with walker/dynomax turbo mufflers has a very throaty and commanding sound without the flow master drone.
Old Aug 26, 2013 | 06:49 PM
bondoboy's Avatar
bondoboy
Corvette central has very nice kits that fit very nicely. Allen's corvette exhaust makes great kits as well. I've had both. I've never cared for flowmasters, too "fake" sounding. If you want the flowmaster type muffler, as having no matting but using sound diverters, try the hooker muffler. They have a lot nicer tone. My brother bought a 98 trans am with a flowmaster on it. It was a little too noisy. We put on a hooker muffler and it got slightly quieter, but had a much nicer performance sound, not just noise. This is all personal opinion.
Old Aug 26, 2013 | 07:05 PM
ddawson's Avatar
ddawson
Really like the sound of my Corvette Central Magnaflow setup.
Flowmaster 40's came off.
Old Aug 26, 2013 | 07:45 PM
74modified's Avatar
74modified
2nd on the Dynomax Turbos
Whatever you do, if you add an X pipe, it will help reduce the drone and add a little power.
Old Aug 27, 2013 | 09:34 AM
Zapawaf's Avatar
Zapawaf
I'll have to check out those mufflers. I called the guy back he said he wOuldn't recommend cats either but I thought they had to be on by law even though fl doesn't require inspections.
Old Aug 27, 2013 | 10:49 AM
rafalc's Avatar
rafalc
Scroll to the bottom of this page
http://forums.corvetteforum.com/c3-g...project-6.html
Old Aug 27, 2013 | 11:00 AM
Patrick73's Avatar
Patrick73
Good sound, good fit and easy installation.
Old Aug 27, 2013 | 12:34 PM
Zapawaf's Avatar
Zapawaf
Originally Posted by rafalc
I heard about pypes a while ago. Is that a bit on setup we could do ourselves? And I've been debating on the X vs H crossover. It was my understanding the H produced more if a muscle sound where as the X was a little more tuned?
Old Aug 27, 2013 | 12:53 PM
rafalc's Avatar
rafalc
Thats what I heard about the H vs X as well. I have not heard both first hand though so dont know or sure.
I went with Pypes even though I read some threads about fitment issues. Good price, complete set up and stainless steel. After the first test fit, everything seems decent. I just need to extend the Hedman header extension pipes an inch or 2.
Old Aug 27, 2013 | 12:56 PM
Zapawaf's Avatar
Zapawaf
Is that a simple fix or will that require welding? Neither my father nor myself are elders, so if we were to install it ourselves it'd have to be something we couldn't have to weld
Old Aug 27, 2013 | 01:01 PM
rafalc's Avatar
rafalc
I guess you can cut a 2inch pipe and use a clamp to attach it to the main pipe. I dont weld either but do have a friend who will weld it for me or I can just take it to an exhaust shop and have them weld it for around $20.
Old Aug 27, 2013 | 01:26 PM
Scott Marzahl
Be careful trying to use a kit designed to bolt up to exhaust manifolds. They are not typically bent to mate up with headers. You/shop will end up cutting the pipes back so the shop can bend up a section of transition pipe to tie the headers and system together. Better off just having a good shop install from scratch. A "H" pipe is fine for your mild crate motor, it will balance the system out fine, easier and cheap to make/install. I would think that if you went with the less expensive walker/dynomax turbo mufflers, no cats and h pipe should be cheaper than $500.
Old Aug 27, 2013 | 07:37 PM
alfaspiderman's Avatar
alfaspiderman
Cruising
I just had a magnaflow system installed. Only thing is that they are turned down and 2-1/2". My 72 has square tips. A little mod is necessary, but will be worth it as it sounds great!!
Old Aug 27, 2013 | 11:03 PM
AboveTheLogic's Avatar
AboveTheLogic
There are quite a few youtube videos out there with different systems on C3s so you can hear what they sound like. I've spent more time listening to C3's on youtube than I'd like to admit
Old Aug 27, 2013 | 11:18 PM
242 Motorsports's Avatar
242 Motorsports
Almost every late model Mustang has an X pipe and the 'zingy' tone that goes with it.
I find the H pipe to be more of a deeper, musclecar sound.
Plenty of YouTube videos but don't limit yourself to C3 uploads.
Listen to any SBC powered vehicle with a true dual exhaust.
The 3rd/4th Gen F-Body with its single transverse muffler will always sound different than a true dual, even with the same brand/style muffler.
My preference is Hooker Aerochamber.
That's what I run on my '84 MCSS and '90 C1500.
Old Aug 28, 2013 | 01:21 PM
Darcy's Avatar
Darcy
I have hooker stainless side pipes on my 76 with a zz4 crate. They sound amazing and really clean up the rear end. Easy to work on the car with nothing in the way and no heat on my feet. Everyone loves a c3 with side pipes. Downside is that you can burn your legs if you forget to respect them. And cleaning burnt rubber off them sucks. Hwy driving at 3500rpm requires hearing protection or you will arrive deaf.
I love the sound of the v8, but if you want a quiet car, this is not for you.
To Exhaust recommendations?
Old Sep 4, 2013 | 11:09 PM
Zapawaf's Avatar
Zapawaf
Sorry for the delay in response, the car is getting towed to the shop tomorrow. I watched a bunch of videos and i think I'm going with the dynomax turbos. I compared the two, I'd probably fall in love with either one the car started up and heard it, but it seems like the dynos are a little noisier with a meaner growl. Might hate that driving down the highway but I didn't get this car to be a daily driver! Thank you for your help guys. Always appreciate it. I'll post a video as soon as she's ready!
Old Sep 5, 2013 | 01:26 AM
mac79vette's Avatar
mac79vette
40 series flowmasters are really loud! I use 50 series delta flow and they are a bet smoother sounding and also a lot quieter than the Dynomax super turbos on my 1979 Corvette. I ran the Dynomax for about a month and felt that they had a bit of a glasspack sound, then went to 40 series flowmasters, but to much noise and then went to 50 series delta flow which have been on the car for about 12 years and I love them! Sold the 40 series to a buddy and made the mistake of putting the dynomax mufflers on my truck. I have been planning(for 12 years) to change them to flowmasters but have not got around to it. Every one thinks the truck has glass packs on it.
If you take a look at the link it has my exhaust build
http://forums.corvetteforum.com/c3-t...st-system.html
But it really all depends on what sound you like. If you like it, it does not matter what anyone else thinks!
Old Sep 5, 2013 | 08:54 AM
rafalc's Avatar
rafalc
and by the way.... online videos will never reflect the sound in real life
