wheel centering rings again
Old Aug 26, 2013 | 07:08 PM
bondoboy's Avatar
bondoboy
Default wheel centering rings again
I posted a few weeks ago about getting wheel centering rings. Can anyone help me figure what size I need? They are sold in metric sizes. I have all kinds of precision measuring tools, but none in metric. What is the standard hub size on our cars? Is anyone running vintage americans, especially 200s? What is the hub size on yours? Thanks again. Not sure why they measure in metric. Isn't thousandths of an inch pretty precise?
Old Aug 27, 2013 | 01:17 PM
MelWff's Avatar
MelWff
I have vintage 200s, about 1980, but am unclear as to why you need centering rings
Old Aug 27, 2013 | 05:15 PM
bondoboy's Avatar
bondoboy
The wheels do not center on the hub like the factory wheels do. The wheel hub opening is bigger for a universal fit. This can be a cause of vibration. My wheels use the shank type nuts, and after 40 years of rotating tires the holes are worn some. I'm just trying to eliminate any problems.
Old Aug 27, 2013 | 05:25 PM
ddawson's Avatar
ddawson
Do you have one of these?
Then measure the bore of the wheel and the hub to get your closet size.
Old Aug 27, 2013 | 05:37 PM
bondoboy's Avatar
bondoboy
No, I have a dial caliper that reads inches. Maybe I can borrow one from someone.
Old Aug 27, 2013 | 06:08 PM
procketus's Avatar
procketus
C4 of Year Finalist (appearance mods) 2019
2017 C4 of Year Finalist
If you measure your hub center with the calipers, you can convert the result by 25.4.
Ex. Say it measures 2.25 inches..2.25x25.4=57.15
Old Aug 27, 2013 | 06:31 PM
JohnRR's Avatar
JohnRR
The use of dial or digital calipers is notoriously inaccurate. It takes some skill and experience to get it right, and even then it's only good to plus or minus a couple of thousands. If you want a precision measurement of the hub, then I suggest you use a micrometer.
John
Old Aug 27, 2013 | 07:34 PM
bondoboy's Avatar
bondoboy
Thanks for the help.
Old Aug 27, 2013 | 11:50 PM
69autoXr's Avatar
69autoXr
The centering ring i.d. should be 70.6mm. You'll need to measure the i.d. of your wheel hub bore to know what size o.d. centering ring to order. I ordered centering rings last year from motorsport-tech.com.
Old Aug 28, 2013 | 03:37 PM
Kid Vette's Avatar
Kid Vette
I have Torq Thrust Ds. The hub OD is 2.78" and the wheel ID is 3.27". Or in metric 70.6 and 83.1
Old Aug 28, 2013 | 04:08 PM
ddawson's Avatar
ddawson
Looking at 101tire they show a some 70.6 inner rings if you want some cheaper rings to start with.
72.62mm. - 70.6mm
73.00mm. - 70.6mm
74.00mm. - 70.6mm
78.00mm. - 70.6mm
Old Aug 28, 2013 | 05:30 PM
bondoboy's Avatar
bondoboy
Thanks again for the help.
To wheel centering rings again
