Possessed Steering Wheel
I've read the archives the Tech Tips and I'm just wondering if someone can break this down for me to make sure I've got it. I replaced the return line to the power steering because of a leak, the other line will be replaced today when it comes in. After attempting to bleed the system (which involves turning the wheel back and forth about four times, or four sets, right?) the steering wheel shot completely back to center, taking several wild turns to do so. Are there some adjustments or things I need to check before assuming this valve I'm reading about is shot? Thanks in advance. I guess I can share some helpful information after all....when playing with the power steering, never, ever stick your arm though the wheel to turn the key when you're standing outside the car. :eek:
[Modified by StrayDog, 9:28 AM 7/1/2002]
What you have to do to correct the problem is pry the dust cap off of your control valve and adjust the nut- check the book to see which way you have to turn it.
Jerry
Jerry
How many miles on the transmission? If you can't find any problems hooking it up, maybe it's due for a rebuild. I don't know much about transmissions yet either- but I was planning on rebuilding my TH350. After talking to some people about it I've decided that it is not something I want to get into just yet, because of a lack of time and garage space. :rolleyes:
Good luck, I hope you figure it out!
Jerry
Good luck
Bob
The transmission is the original and has about 43,000 miles on it, though I suspect they were pretty hard miles.
[Modified by StingRayPonyGirl, 2:10 AM 7/5/2002]
I retired from Delphi Saginaw Steering Systems (formerly Saginaw Steering Gear Division, GMC) a year ago. I worked in steering systems engineering most of my 39 year career. Since retirement, I have a worked up a whole set of instructions on the C3 Corvette steering system. They can be found at http://www.corvettefaq.com in the Steering section. These instructions along with a good Chevrolet Service Manual and a Chevrolet Overhaul Manual can be a big, big, help in working on your Vette.
You may find the instructions a bit wordy, but they do lay a good basis as to how and why the steering system works.
Have you adjusted your control valve? I know that you mentioned that the steering wheel "took-off" when you first started your car. I suspect that large quantities of air in the steering system can also cause the steering wheel to rotate in the manner that you described. So I guess my question to you is; has the steering improved by itself, or have you adjusted the valve?
Some of the papers that are posted at corvettefaq.com that could be of help:
Control Valve Replace and Balance Instructions
Hose Connections - Flare versus O-ring
P-Pump Leak Points Pic
P-Pump Parts Repair and Replace
Pump Pulley Attachments
Steering Hose Routings (all engines)
Steering Hose Routing (pic) pump to valve
Steering Hose Routing (pic) valve to cylinder
Disconect the pwr cylinder from the frame. (I blocked mine up with wood to keep it from hanging). Start the car, and observe the cylinder. If it retracts, SLOWLY turn the adjusting nut (under the dust cap on the valve) clockwise untill the rod starts to move out from the cylinder. If the rod shoots out, adjust the nut counter-clockwise till it starts to move in. Now adjust the nut to the half way point between in/out movement. The cylinder rod should be free to move in and out by hand once this is done. Be patient, cause the cylinder rod will not react immediatly after turning the nut. Again... turn that nut slowly, and observe the amount you turn it, between in and out movement of the rod. I was a little nervous doing this (first time) but I took my time, and it turned out perfect.
Hope I've helped...Good Luck
Eddie :cheers: :cheers: :cheers: :cheers:
You really can't screw up assembling the pressure and return line hose. (They can be routed incorrectly so they are rubbing against things, or routed so that when you make full lock turns they are hitting and rubbing things.) But you can't interchange them, one for the other.
However, you can interchange the two hoses going from the valve to the assist cylinder. They should criss-cross coming out of the control valve. Please refer to Steering Hose Routing Pic Steering Hose Valve to Cylinder at the corvettefaq websight if there is any doubt as to the connections.
