'Pressurised' Roller Lifters
There have been threads and articles re. pro's and con's of roller lifters and whether hydraulic or solid rollers are best for certain applications. One thing for sure is that it seems a number of users or solid roller lifters have experienced lifter failures. Many people seem to exclude the idea of solid rollers for street operation citing oiling issues with typical street operation (i.e low rpm use and extended idle periods) which, yes I guess is a potential problem IF using a race spec' cam/lifter/spring set up with very high spring rates and perhaps if an engine has lower pressure than ideal at idle. Certainly the pro's and con's of suitable oils with ZDDP additive etc are also part of the issue.
It seems that two or three of the cam and lifter manufacturers are now marketing what they are describing as 'pressurised' solid roller lifters, which I guess (as presumably getting their oil supply from the lifter gallery) would theoretically seem to address some of the low rpm oiling issues.
For me the 'engineering' and efficiency benefits of a solid roller win 'hands down' (theoretically anyway) and a solid roller application for street use with 'sensible' valve lifts and spring pressures is surely the way forward? - thoughts/comments./'real world' experiences?
The most reliable out there I believe is the bushing type. Morel and Isky sell them. Not cheap but they do well. I have a buddy with several years on a set of Isky's that are still perfect. (He just ckd them last weekend). It's a 7000+ RPM motor that he drives everywhere and beats the heck out of.
I've used Comp, Crane and Lunati pressurized in mine over the years. In fact I got one of the first sets of Comp prototypes to test and then after 2000 miles we rebuilt them to use their improved axle assy. I used them for years and rebuilt them a couple of times. I've got Crane's in it now and they are excellent pieces.
My cams are in the .775" lift range usually with crazy spring pressure. I typically rebuild/replace them every couple of years depending on how many miles I put on them. Until this year that was typically 4-6K miles per year. Sometimes more. There was always at least one 2000+ mile road trip in the mix.
Solid rollers are fine for street use with cams that aren't too crazy and if you keep an eye on them for lash issues.
But these days...I have to admit the *good* hyd lifters like Crane and Morel's are doing 6500+ RPM in big blocks with no issues. Smallblocks are going over 7000 easily. Just need the right cam lobes in there and the right lifters.
JIM
Using old Crower non oiling lifters street use idling etc not too many miles but in there for yrs so far so good.
Honestly I dont worry about it. Have checked lash many times 0 movement. When something sounds funny then Ill check into it.
Everything wears out just part of the game
He had found a shortblock to rebuild one time and wanted me to do it. It had hypereutectic pistons in it and I told him the only way I'd do it was if we put a rev limiter on it because I know how he drives. He decided to wait a while and this is what we came up with!
JIM
In that video it has a wide ratio Muncie in it....the boy can drive!
Just for fun....and not to hi-jack too bad (hey..it has pressurized solid roller lifters in it!).....here's a video of mine at the track one night....grabbed 4th right at the 1/8th mile mark.
JIM
In the end, we backed off the spring pressures a bit (to 160# at seat) to increase durability, but this came at the expense of redline. Engine was built to be good to 7k+ RPM, but we'll redline at 6,500 (probably set MSD box at 6,300 or 6,400) to make sure there's no valve float. I'm running a ~0.590 lift cam.
The biggest thing on solid engines is lash. Too much, and those roller tips take a huge beating. Weak springs, and it gets even worse. Too many RPM's and it's worse still.
I'm running a Comp XR286 cam with a "tight lash" (0.016/0.018) spec. I'm running aluminum heads, so we're actually going to tighten that up even more on the test stand. I may end up in the 0.012 range (cold adjustment) before it's all done. We're also running really nice Comp lifters in hopes that they last.
Valve crashing is a solid roller killer. Hydraulic lifters at least have 'cushion' if you get outside the sweet spot. Solid lifters just get destroyed.
Plus, I pulled 2 horribly bent pushrods out of my engine before I disassembled it. And my valve crowns were all chipped up.
Granted I was running a flacid 60# spring pressure (1978 springs), but I'm starting off by being a little nutty about lash. That's the starting point for all the problems.
The springs on those rev kits don't stand a chance at 7 grand - big valve springs have a tough enough time keeping everything where it should be with 300-400lbs of seat pressure. I saw a high speed video taken in a lifter valley with a rev kit, will post it if I can find it. There wasn't a single spring that stayed seated above about 6500rpm, they were bouncing all over the place.
