Doing some planning for the engine reinstallation. What do you guys recommend for the clutch-throwout bearing? Its going in a 454 four speed Vette...the engine will be putting out a little under 400hp. The existing clutch doesn't look too bad, maybe measure it and reinstall?
I would resurface the flywheel and at least put in a new disk, but that's just me.
The throw out bearing that came with my RAM clutch was made in China. While I was fitting it to the clutch fork, the rear ring section of the bearing popped off. The ring was not swedged on well enough and the Speed Shop where I bought the clutch was aware of the problem.
The GM bearing is avaliable - #15680264
I picked up a "Made in USA", National #614018 for about $19 at Advanced Auto.
Make sure the clutch fork/spring is in good shape.
