Lowering my 78 help
Old Aug 30, 2013 | 09:01 AM
psublett's Avatar
psublett
Default Lowering my 78 help
Just put 18" 245/45 front and 255/45 rear bolt on no spacer or adapters. Original suspension...want to lower front maybe 1.5" and rear maybe .75-1"
ill try to post a pic
Old Aug 30, 2013 | 09:10 AM
oldalaskaman's Avatar
oldalaskaman
cut one full coil from your stock front springs, and use the longer bolts on the rear, did that to my 76, works great an didnt break the bank
Old Aug 30, 2013 | 10:33 AM
addballer696's Avatar
addballer696
may as well upgrade suspension while your at it. But yeah removing the coils is very easy compared to some other cars. Just gotta get that first one done then its a breeze. I bought moog coil spring replacements for cheap rated around 500lbs, cut 3/4 coil off and dropped it about 1.5 inches.
Old Aug 30, 2013 | 08:24 PM
Ibanez540r's Avatar
Ibanez540r
Curious to see pics, that's the size front I went with. (early stages of frame off)
Old Aug 30, 2013 | 08:50 PM
Ely's Avatar
Ely
Cutting the coils seems like a good idea.
What about the shocks? Seems like you would now be more likely to bottom them out now that you are starting out 3/4" short. Did you add a 3/4 " spaced on the bottom so the shock length stayed the same after you cut the springs?
Old Aug 31, 2013 | 11:31 PM
couperdecar's Avatar
couperdecar
If you're going to cut the spring , go with Bilstein Sports. The sport is stiffer and has a shorter valving for lowering springs. The Bilstein HD's are more comfortable and have longer valving.
Old Sep 1, 2013 | 10:24 AM
gcusmano74's Avatar
gcusmano74
When you cut a coil off the spring, you not only shorten it, but you stiffen it as well. Removing just one coil shouldn't change things dramatically.
Old Sep 9, 2013 | 07:36 PM
psublett's Avatar
psublett
thanks, so I should be fine cutting 1 full coil off correct? Roughly how much will that lower the front end?
Also, using the 10" bolts to lower the rear end. Is there fluctuation with the amount you can lower the rear with the bolts or is it a set number?
Old Sep 10, 2013 | 12:12 AM
cagotzmann's Avatar
cagotzmann
What is the offset of the wheel you purchased. Any problems with fit in the back where the parking brake cable on the trailing arms ?
Old Sep 10, 2013 | 12:15 AM
psublett's Avatar
psublett
4" BS no issues with fitment
Old Sep 10, 2013 | 01:03 AM
oldalaskaman
lowered mine right at 1 1/2" on the front , used an angle grinder cut just like butter. looking at your picture, lower the front first, bounce it down the road a bit, align it and then lower the rear. that way you can use the rear to level it also. you can take the rear all the way down to the end of the threads if thats what it takes. you will also need to set camber and toe on the rear. I used nylocks and also drilled a cotter pin hole. best to keep at least three threads below the nut. C4 stock spring bolts are 10", folks over there might give you a set cause when they lower theirs they use 12" bolts. hope this helps
Old Sep 10, 2013 | 11:49 AM
psublett's Avatar
psublett
thank you, so you cut 1 coil and it lowered 1.5"?
Old Sep 10, 2013 | 12:29 PM
ramair_bryan's Avatar
ramair_bryan
Sounds easy.........But those coil springs are the hardest job putting back in, even after I cut 1/2 coil.
will look good though...........
Old Sep 10, 2013 | 01:40 PM
psublett's Avatar
psublett
so do I get C4 10" spring bolts?
Old Sep 10, 2013 | 01:48 PM
Ibanez540r's Avatar
Ibanez540r
Typically the 8" bolts are the upgrade to lower the rear. Stock are 6.5". Some guys have gone to 10", but have had to cut a little off as they are so long they can hit the ground.
I'd do 8" and see where it gets you.
http://www.vbandp.com/auto-parts/c2-...ategory_id=113
Old Sep 10, 2013 | 07:49 PM
oldalaskaman
yes it lowered it 1.5 inches
the coil springs are not difficult to remove, only takes time , a diy spring compressor documented in willcox tech papers does wonders. they are very easy to re install once cut,
the C4 bolts work fine, if they wind up being a bit long after you have your height...use that angle grinder and cut them off. better to much than to little, I hate doing things twice. if you ask in C4 those folks will probably send you some for free I used my 10" C4 bolts on my C3 , no issues
To Lowering my 78 help
