dart shp short blocks
It was my experience that the 294 cam was kind of wimpy for my 427. I would also stay away from the crappy pot metal Comp Cams and get the billet steel with a sleeved dizzy gear
does the intake port size match up to the Dart 215 port size without mods?
Holley#510-300-25
Strip Dominator Intake Manifold
Small Block Chevy
4500-7600 RPM
Single plane/open plenum
No heat crossover provision
Height: 5.11" front/5.97" rear
Port size: 2.05" tall/1.22" wide
Square flange/4150 carb pad
We tested it with a 2x4 WCFB carb setup and a Dart dual plane and a Weiand single plane using a 750 Holley.
As far as quality, everything fit as expected and it's been running fine with no issues at all.
JIM
You could have a hogged out bowl way out of proportion to the throat area that would kill flow a lot more than if the short turn or runner was opened up and matched to the intake runner correctly.
A "good" set of "big" heads will still make more TQ than most think....while at the same time a poor set of "big" heads may still not make the big top end power. Same thing holds true for "small" heads....they may not do that well down low..yet some of them do well up top.
Look for combinations that are proven to do what you need rather than worry about a specific airflow number or head cc.
JIM
JIM
Thanks in advance Blue
It used forged flat tops and 64cc heads to end up with 11.0 compression. The heads were out of the box Dart 200 cc heads. The point of the build was to take everything out of the boxes and bolt it together in a weekend and strap it to the dyno. I didn't do any hand massaging at all...and that's tough for me!
I knew it would ultimately end up with the 2x4's and WCFB's. It went into an original 283/270 car and the original engine was stored. This one was disguised to make it look as stock as possible. That poor old intake was ported to within an inch of it's life. We'd have taken out more but the integrity of the casting would have been compromised. Even after porting it was obvious it was too small to feed 400 cubes...and the dyno sheets show that.
The cam was selected after lengthy discussions with Billy Godbold who is Comp Cams head designer. We spent a lot of time discussing "where" the restriction was. The carbs(no), the ports (no)...the intake (yes). Same discussion on exhaust...was restriction in the head (no)...the headers (no)..the factory manifolds (yes)...the exhaust pipes (yes)...the mufflers (yes). Spec'ing the cam a little differently allows you to play with the compromises. You do the best you can...and in this case it worked pretty well when the restrictions were lifted by adding better intakes/carb.
You have to think a little of the differences in a NASCAR type motor with killer heads and a tiny 390 cfm carb...or a circle track motor with weak heads and a 2BBL. Both are restricted on the intake side...but they both need a different cam based on where the restriction is.
In this case we used a 248/248@.050 on a 109 LSA cam. It used the intake lobes from the XR286 cam on both intake and exhaust with 1.6/1.5 Comp rockers to create .614/.576 lift. This was a good bit of duration but we had to add some to deal with the restriction issues. If running with either of the "good" intakes and headers it would have likely had less duration on both sides with a 4-6* split and a tighter LSA. When it was done it made power right where we wanted it to.
Our shortblock came with a .021" deck and with the .039" gasket made for .060" total quench which is more than I would have preferred..but it turned out OK with a final 11.0 compression. It works fine on 93 octane in Houston heat.
I highly recommend ordering the forged pistons on any engine like this. I would also suggest upgrading to 7/16" rocker studs if using a solid roller in any smallblock.
I used a stock Melling oil pump with a high pressure spring. The oil pan was a stock GM passenger car pan to keep stock look.Not even a "good" one with baffles...just a plain pan. Certainly a better pan would have helped power even more.
Here's a video of when we fired it up on the test stand to give you an idea of what it sounds like with open pipes and manifolds.
JIM
JIM
