3:70 rear test run
Old Jul 1, 2002 | 02:14 PM
MIDNIGHT BLUE's Avatar
MIDNIGHT BLUE
Default 3:70 rear test run
we got the rear in this weekend was a major PITA i now beleave in Murphy's law. well we did get it on the road sat. night ,went from a 3:08 to 3:70 . the car has a 454 LS6 and was already quick . it was like a different car the 3:70 gear felt strong i could see a in crease in RPM's rev up much faster. after a few 1st to 2nd runs the half shaft came apart :( we'll see what caused the brake down fix it :smash: and try again :cheers: i'm hoping it's just to much HP :D jim
Old Jul 1, 2002 | 02:53 PM
Tominator's Avatar
Tominator
Default Re: 3:70 rear test run (1970LS6)
I'm running 3.36 gears and hope to change some day too! Sounds like your building a nice set up :cheers:
Old Jul 1, 2002 | 02:57 PM
Alwyn678's Avatar
Alwyn678
Default Re: 3:70 rear test run (Tominator)
Sorry to hear that it broke......My car improved Dramatically when I did the rear from 3:08 to 3:73......Like night and day..What caused the Breakage..I did not romp on mine until like 150 miles had ticked by..They say to create a "wear pattern" on the gear
[Modified by Alwyn678, 2:33 PM 7/1/2002]
Old Jul 1, 2002 | 03:33 PM
Aaron-74's Avatar
Aaron-74
i went from a 190Hp to 350 and a 3.08 to a 3.70. I can't wait to drive it. It will be like death and life...
Old Jul 1, 2002 | 03:38 PM
GTR1999's Avatar
GTR1999
Good to hear,hope you get the 1/2 shaft fixed ok. I have just over 400 miles on the 373's I installed. The only problem so far was the parking adjustment was too tight after I rebuilt the rear bearings and arms.
Gary
[Modified by gtr1999, 12:02 PM 7/2/2002]
Old Jul 1, 2002 | 11:05 PM
69L71's Avatar
69L71
What trans are you running? A 3.70 might be a bit steep with a WR 4-speed like an M-20. Overal Drive Ratio in first would be the same as a 4.27 rear and an M-21. With all the torque of the LS-6 you're gonna have a tough time either: A) getting traction, or B) breaking stuff.
Looks like you've had your first taste of B
Old Jul 2, 2002 | 12:29 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: 3:70 rear test run (Aaron-74)
Same here -- L-48 to ZZ4.
3.08's in there now --- 3.73's will be in there in 2 1/2 weeks.
I have the 700R4 transmission -- should make for some awesome first gear launches (tire smoking).
Old Jul 2, 2002 | 11:41 AM
467-Ratman's Avatar
467-Ratman
I changed last year to a 3:70 rear gear, and now I have my BB 467 with the Muncie M-20. Things happen real fast with that setup!!!!! I had a 3:36 originally that probably would have been fine with the BB. It sure gets going fast, on the down side I am spinning 3100 rpms at 60mph. Like someone said it really depends on what tranny you have. For my setup the 3:55 would most likely been a better choice.
Old Jul 2, 2002 | 07:04 PM
MIDNIGHT BLUE
got the half shaft and flange off last night looks like we didn't have the clips seated good. put a dent in the shock and another on the cross member the half shaft and flange are dameged and need to be replaced. but that seems to be all. well i'm not sure what trans. is in the car , i was told by the past owner it is a m22 but i'm not sure. all i know is it screams now. jim
Old Jul 2, 2002 | 08:08 PM
70PurpleLS7's Avatar
70PurpleLS7
If in 1st and 2nd you can hear the transmission over the engine, then there's a pretty good chance it's a M22, it almost sounds like a granny gear in a truck in the first two gears.
Old Jul 2, 2002 | 09:32 PM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
Default Re: 3:70 rear test run (70PurpleLS7)
[QUOTEIf in 1st and 2nd you can hear the transmission over the engine, then there's a pretty good chance it's a M22, it almost sounds like a granny gear in a truck in the first two gears.[/QUOTE]
or a noisy camshaft gear drive ......
Old Jul 3, 2002 | 03:45 AM
Berserker78's Avatar
Berserker78
What are you going to do with your old 3.08? If you are interested in selling it, would it fit my 78?
Berserker78
corvetteakio@hotmail.com
Old Jul 8, 2002 | 02:36 PM
The Money Pit's Avatar
The Money Pit
I haven't worked up the nerve to really lay into mine yet. Pulled 30 feet off the line the other day,and backed off it with the tires still spinning!
To 3:70 rear test run
