will this tire fit?
Old Jul 1, 2002 | 02:20 PM
Rick C.'s Avatar
Rick C.
Default will this tire fit?
Now I am running 275/60r 15s out back. The car has flairs and 10 inch wheels. I have found some 295/50 r 15s does anyone know if they will fit ?or what the size diference would be? the tires on the car now fill the fenders and look good but I want more tire on the ground and a slightly smaller diameter would help gearing but to much would hurt the looks of the car.
The tires are on ebay and I have emaild the seller for the info I need but have not heard back.
Old Jul 1, 2002 | 06:40 PM
The Money Pit's Avatar
The Money Pit
Default Re: will this tire fit? (Rick C.)
I've been running P295's for years without a problem on the stock 8" rims. Just went to Weld Draglites 15x9" this spring.
Old Jul 2, 2002 | 12:02 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: will this tire fit? (The Money Pit)
295's will rub your parking brake cable bracket on your trailing arm unless you move it or grind it down
Old Jul 2, 2002 | 12:11 AM
Rick C.'s Avatar
Rick C.
Default Re: will this tire fit? (MotorHead)
can the park brake be retaind if I grind the bracket down or will it be renderd unusable?
Old Jul 2, 2002 | 12:24 AM
NHvette's Avatar
NHvette
Rick, it looks like you have aftermasket wheels, which may have a different
offset from the stock ones. I would check underneath right now, and see
how much clearance you have around the current tires. The 295s should be
about 1cm wider on each side from 275s.
Old Jul 2, 2002 | 12:36 AM
'79ProwlerOrange's Avatar
'79ProwlerOrange
Default Re: will this tire fit? (Daves_rusty_75)
it may it may not fit. since you have flares and wheels that use the flare nicely then you shouldnt have any problems running a tire thats 2cm wider. but best thing to do is just check the clearance like dave said. if it dosent look like it will hit anything it probably wont. take it to a tire shop and ask them their opinion. i know most of the places arround me would be happy to take a look and see if its possible.
Old Jul 2, 2002 | 10:29 PM
Rick C.'s Avatar
Rick C.
Thanks for the info I just had a good look ans if I am looking at even 3cm I will be ok so I am going to try an get the tires.
Old Jul 2, 2002 | 11:18 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
You mean, yours actually works? that seems to be rare on these beasts
Old Jul 3, 2002 | 12:09 AM
MotorHead's Avatar
MotorHead
Default Re: will this tire fit? (Markm10431)
Make sure you look right where the parking brake bracket is, it will cut down your tire in a second if it touches, I grinded mine down considerably and it still works
[Modified by MotorHead, 10:11 PM 7/2/2002]
Old Jul 3, 2002 | 04:01 AM
PrarieShark's Avatar
PrarieShark
From: The cure for the blues is eight cylinders roaring
A 295 would be over 11.5in wide tread width and would be about 26.5in tall
295 devided by 25.4=11.61 tread width
11.61x.50=5.805x2=11.61+15=26.61 tall tire.
[Modified by Wightnite, 3:04 AM 7/3/2002]
To will this tire fit?
