ac low pressure switch
Old Aug 31, 2013 | 01:09 PM
namvet6869's Avatar
namvet6869
Default ac low pressure switch
will the ac low pressure switch on my 81 work with r-134a??? hope I am about to get all these problems solved. thanks, nv
Old Aug 31, 2013 | 02:55 PM
bpassmore's Avatar
bpassmore
It should, there is a screw between the terminals, turning it CCW lowers the pressure the contacts open, allowing the compressor to run longer creating a lower outlet temp. About 2 turns usually does it.
Old Aug 31, 2013 | 02:59 PM
hugie82's Avatar
hugie82
I had no problem when I did my 82. Pretty much the same system. Put a little loc-tite on the adapters high/low . They like to spin off with the caps and the soft aluminum starts getting messed up over the years.
Old Aug 31, 2013 | 07:30 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
change the o-ring and you're good to go
To ac low pressure switch
