Heater Core - Repair or Replace
Old Sep 1, 2013 | 08:06 AM
shaw1974's Avatar
shaw1974
8th Gear
Default Heater Core - Repair or Replace
Just finished removing the heater box in my '76 to fix some vacuum lines and noticed the heater core is the original Harrison model. Considering the time and effort this has taken, was considering changing the heater core profalactically, even though the original is not currently leaking. After reading several posts on the poor quality of the cheap replacements available today, I've narrowed it down to three options.
1. Pressure test and use the current core as is.
2. Replace it with a new aftermarket (any suggestions on which is best?).
3. Have the original recored (any suggestions on who could do this?).
Look forward to hearing everyone's suggestions.
Thanks!!!
Old Sep 1, 2013 | 08:46 AM
Jig A Low's Avatar
Jig A Low
I guess it depends on how you luck runs---YOU may get another 50 years out of it, if it were ME, it would fail about 10 minutes after I got it all back together and on the road.
considering the work it is to get out, I would most certainly replace it. can't help you with the "quality" aspect of it though. you could check with a radiator shop and see if they can check it out/recore it for you.
Old Sep 3, 2013 | 05:40 PM
shaw1974's Avatar
shaw1974
8th Gear
Well I guess just like everything else, it comes down to money. Recore will be around $150, but with quality supplies made here in the USA. Or $50 from one of the parts houses, and a roll of the dice on a foreign made replacement. Decisions.....decisions.......
Old Sep 3, 2013 | 06:15 PM
hugie82's Avatar
hugie82
I would replace it. Even the Chinese cores are better than a 40 year old core. I think I got mine from summit racing or rockauto 2-3 years ago. No problems and it looked well made. If it looks cheap, ship it back
I would pressure test it if you can, I didn't and I was worried the first few minutes. Plus it gives you a chance to clean out the trash in there along with replacing the door seals
Old Sep 4, 2013 | 08:07 PM
yyz1970's Avatar
yyz1970
I bought a made in Mexico heater core from Corvette Central
no problems
Old Sep 4, 2013 | 08:19 PM
PeteZO6's Avatar
PeteZO6
You don't say if you have A/C or not. Even though the factory service manual tells to remove the heater core from the interior side, on early non-A/C cars it is easier to remove it from the engine side.
So.... still a crapshoot, but if you don't have A/C, it might be worth it to take a chance on your original. I think I would have a competent radiator shop check it over carefully for any weakness and if OK, go with it.
Pete
Old Sep 4, 2013 | 09:57 PM
maxmachz's Avatar
maxmachz
Do you need heat in the car? If not, just leave it in there, and bypass it..........
If yes, leave it be. Fix what is broken, other wise you'll be replacing everything in the car.
To Heater Core - Repair or Replace
