68 frame
Old Sep 1, 2013 | 08:04 PM
SB64's Avatar
SB64
Default 68 frame
Can a 68 frame be used on a 69 coupe. Any alignment or other major differences?
Old Sep 1, 2013 | 09:02 PM
wombvette's Avatar
wombvette
Much different in the front, and the 69 has some beneficial modifications. It would be best to find a 69-72.
Old Sep 2, 2013 | 11:19 AM
SB64's Avatar
SB64
Default 68 frame
Thanks, I can use 69 - 72, they will fit????
Old Sep 2, 2013 | 03:19 PM
wombvette's Avatar
wombvette
Yes
Old Sep 2, 2013 | 03:54 PM
gbvette62's Avatar
gbvette62
The only difference that I'm aware of, between the 68 and 69-72 frames, are 2 additional gussets in the rear. These gussets were added from the crossmember by the number 3 body mounts, up to the rear frame kick ups. If you have access to a good 68 frame, you can add the 2 gussets to the 68 frame. You can buy the gussets new, for about $50 each, or possibly remove the old ones from your 69 frame.
The 68 front frame extensions are different than 69-72 extensions, but these are bolt on's, so you should be able to reuse your 69 pieces.
Old Sep 2, 2013 | 05:16 PM
SB64's Avatar
SB64
Default 68 frame
A member has a 68 rolling chassis for sale in TN. Looks pretty good just wasn't sure if it would work, thanks regards R
To 68 frame
