Torque converter help
Old Jul 1, 2002 | 08:46 PM
78MoneyPit's Avatar
78MoneyPit
Default Torque converter help
78 L82, eliminator intake, 650 Holley, 268 cam. I'm not happy with the low RPM power, but I was told putting a 2100 Torque converter would make me unhappy as a street driver. They said I would always have to rev up just to get going and it would get old fast. Any input?
Old Jul 1, 2002 | 09:45 PM
MIKER's Avatar
MIKER
Default Re: Torque converter help (78MoneyPit)
What transmission and gears are you running? What type of driving do you do? What price range did you have in mind?
Torque converters can be a DEEP subject and I don't know squat about them in the big scheme of things. However, the torque converter that my trans builder made for me is supposed to provide a stall speed of ~2400 stall with my combination. This is the first time I have owned a car with a modified torque converter so I cannot compare it to anything but stock.
During normal driving, when accelerating from a stop I can't tell much difference but when you nail it from a stop, it will flash to the higher rpm range and BAM. . . your off and runnin' or roastin the tires as the case may be. This happens so quickly, you hardley even realize it.
There are a lot of variables to selecting the right converter for your car and opinions will vary. I think that you are in no danger of overdoing it with the 2100 converter that you are considering.
Search the forum's recent topics and archive topics for relevant information. You should find a LOT to read. Just search for the word "converter". http://forums.corvetteforum.com/zerosearch
Old Jul 1, 2002 | 10:21 PM
78MoneyPit's Avatar
78MoneyPit
That's my basic question. First I was told to get a stall converter to get up to the power curve, then a guy at the shop where I was going to have it built told me I would have to get to that RPM just to drive. If I can usually drive normally I would like to do it, cause getting out of the hole is embarrassing. My secondaries won't open until 4200 RPM or so. No vaccuum with the 268 cam. Any other ideas?
Old Jul 2, 2002 | 12:07 AM
MIKER's Avatar
MIKER
Sounds like your secondary air valve spring needs to be adjusted. Check out this Q-Jet Tuning Paper written by Lars. http://corvettefaq.com/c3/QJet_Tuning_Paper.doc Lot's of good information like this can be found at corvettefaq.com
Unless there are other problems, your "268" cam should allow >14+ inches of vacuum. Can you provide more details about your car?
. . .then a guy at the shop where I was going to have it built told me I would have to get to that RPM just to drive. If I can usually drive normally I would like to do it, cause getting out of the hole is embarrassing. . .
Sounds like their was some miscommunication. You definitely do not have to rev the engine up to the proposed stall speed before the car will move. Now for extreme speculation, I'm SURE that if you were to install a 5000 rpm stall converter in your street car, it would feel pretty crappy.
Old Jul 2, 2002 | 12:49 AM
78MoneyPit's Avatar
78MoneyPit
Default Re: Torque converter help (MIKER)
What would you suggest? Drive it normal most of the time, but when I want to go, I want to GOOOOO! Stock rear end and trans, mild shift kit. Low vaccuum causes secondaries to open at high RPM. 650 Holley. Low vaccuum also causes lights to rise slowly and soft brakes. 268 cam
Old Jul 2, 2002 | 01:42 AM
MIKER's Avatar
MIKER
You need to investigate the reason why your vacuum is so low.
I doubt that this low vac condition is cause by a cam with an advertised duration of "268".
Old Jul 3, 2002 | 09:42 AM
Ganey's Avatar
Ganey
More info. is needed. CS268H or XE268? Rebuilt or just added cam? For ex., have seen a 268H installed & accel. slowly till about 3000 & took off. 2100 is a mild converter, would not be a problem. You should determine current stall. Sec. should open sooner.
Old Jul 10, 2002 | 05:40 PM
The Money Pit's Avatar
The Money Pit
I ran the 268H in my 355 for 6 years and had no problem hitting 5500-6000 rpms. The problem may be restriction in the exhaust. A freind of mine built what should have been a decent 350 for his MonteCarlo and it had a two barrel carb and single exhaust. To be blunt,it sucked out of the hole,and had no top end either.
I ran a B&M Holeshot 2000 with 3.70 gears then , and had no trouble launching. My theory is if you can spin your tires on the launch,they are not big enough. Most of your ET losses come from the first 60ft,so if you spin,you're wasting time. If you engine can't pull hard enough to spin them,it's time to replace it with one that can.You see the circle effect here?
As far as torque convertors go,the 268H isn't much bigger than a stock cam,so a high stall isn't needed.
[Modified by The Money Pit, 9:43 PM 7/10/2002]
Old Jul 11, 2002 | 08:40 AM
DeenHylton's Avatar
DeenHylton
Go with a 2100 or 2400 stall...you won't be dissapointed. I ran a 3000 stall for awhile (TCI) and it wasn't too unpleasent for everday driving...I switched to a 4000 stall and would NOT consider the car an everday driver anymore (short trips only).
Get the secondary spring kit from Holley and swap your secondary spring with the "purple" spring...should get you in the ball-park. Deen
Old Jul 11, 2002 | 09:27 AM
Alwyn678's Avatar
Alwyn678
Default Re: Torque converter help (DeenHylton)
I have a TCI 2400 stall and it is perfect for my application...Really works well with the 3:73's that I installed......Helps put the power down :smash:
Old Jul 11, 2002 | 05:17 PM
78MoneyPit's Avatar
78MoneyPit
Default Re: Torque converter help (Alwyn678)
You say for your application, what is it. Mine is a daily driver. I'm getting mixed messages. I want to be able to drive normally most of the time, but I want the power when needed. (Is that a cake and eat it too problem?)
Old Jul 11, 2002 | 05:35 PM
Alwyn678's Avatar
Alwyn678
I would think it would be fine as a daily driver....I just do not drive mine daily....
Old Jul 11, 2002 | 05:54 PM
terryrudy's Avatar
terryrudy
How much of a pain is it to install the Torque Converter. Even with my current setup (stock carb, edelbrock egr intake, trick flow alum heads, hedman headers, true dual 2.5" exhausts, TH350, 3.55s) I cannot chirp the tires at all. Granted my tires are a little sticky (255-50-17 Z-rated) but I would expect to at least be able to roast them off the line just a little. :)
So now my quest has left me at the tranny. I plan on putting a shift-kit in next. Could my torque converter be bad? I am thinking of moving up to a 2400 stall tq converter as well.
How tough of an install job is it? Do I need to remove tranny or anything that involved?
thanks!
-terry
Old Jul 11, 2002 | 09:18 PM
Alwyn678's Avatar
Alwyn678
Default Re: Torque converter help (terryrudy)
thanks!
-terry
Yes you do have to drop the tranny to remove the tourque converter...It is a decent job but well worth it...You can also do the shift kit at the same time...I did with a B&M kit ..It is not so hard that you can't do it yourself with help on jackstands...I did mine with another friends help...I could not smoke my tires but after the converter and the 3:73 install I can light them up with a press of the gas pedal......That alone is worth it
Old Jul 11, 2002 | 11:25 PM
Tominator's Avatar
Tominator
You are going to get a lot of mixed reviews on convertors and cams, but that what great about this forum, many guys here with lots of expereince.
I am going to answer your question, but keep in mine this also is just an opinion too.
You don't need to go to a bigger stall but I think you should. I like you am not happy with my low torque and went with a 1800 -2200 stall, am I happy no! I wish and am some day going to a bigger one. Although my cam is 222@50 and 470 lift
If you go with the one similar to mine you won't notice hardly any differnce in daily driving.
Before you make a move keep asking question until your satified, try to narrow them down and you should be able to find your answers your looking for.
To Torque converter help
