carb question
Old Jul 1, 2002 | 09:03 PM
03whitecoupe's Avatar
03whitecoupe
Default carb question
My car idles at around 400 rpm in drive and I need to adjust the idle speed but I don't know which screw on my Carter Quadrajet is the idle speed screw. Is there any easy way to determine the idle speed screw? There are several screws on the carb that it could be, and in my ignorance I can't figure out which one it is. Any help would be appreciated. :bb
Old Jul 1, 2002 | 09:29 PM
JB's Avatar
JB
St. Jude Contributor
Default Re: carb question (midget)
A Carter? What year? I know some midyears had Carters, but I didn't know any C3s did.
Wish I could tell you where the idle mixture screws are, but I've never messed with a carter. Probably two screws, probably in the throttle plate, but someone else here will know.
[EDIT: on second thought, Carter didn't make Qjets, Rochester did. Do you mean a Rochester Quadrajet? If so, what year? My '69 has idle mixture screws in the front of the throttle plate and an idle adjusting screw on the forward drivers' side of the carb that screws in and out to limit how far the throttle can go back.]
JB
[Modified by JB, 8:23 PM 7/1/2002]
Old Jul 1, 2002 | 10:02 PM
Larry B.'s Avatar
Larry B.
Yes. Carter did make some Quadra-jets under contract from Rochester. They are exactly like Q-jets except the "carter" name. The normal Idle speed screw is on the driver's side near the arm that the throttle cable hooks to. It directly moves the arm. turning the screw clockwise (in) should increase the idle speed.
Old Jul 1, 2002 | 10:13 PM
JB's Avatar
JB
Default Re: carb question (silvervetteman)
My bad. Learn somethin' new every day. :D
JB
[Modified by JB, 8:22 PM 7/1/2002]
Old Jul 1, 2002 | 10:26 PM
PRNDL's Avatar
PRNDL
Default Re: carb question (JB)
Follow the instructions above and you should be OK. On the other hand, if you look at the illustration in my Haynes manual, the labels for the mixture screws and the idle speed screws are mixed up!!! :mad
Very confusing for me as a newbie!! MJ
[Modified by MNJack, 9:27 PM 7/1/2002]
Old Jul 2, 2002 | 01:48 AM
Stevo81's Avatar
Stevo81
Default Re: carb question (MNJack)
Don't ya just hate that. My favorite pet peeve is when the books call the same thing by three different names. As a teenager, all I had to learn from was books. With crappy old cars, rusted up, one Chiltons (probably for the wrong year)......and no forum !!! :seeya
Old Jul 2, 2002 | 11:21 AM
fontking1a's Avatar
fontking1a
The idle speed is generally a "stop" and can be located by pressing the gas pedal and watching the throttle cable. As the cable moves and then returns to its original point, there is a screw that can be turned in (to raise) or out (to lower) the amount of throttle cable movement. Turn that screw one half turn clockwise and see if your idle speed increases. If nothing happens...you've got the wrong screw. Hint:* The screw usually has a pretty big head on it.
Old Jul 2, 2002 | 11:43 AM
Neo Fender's Avatar
Neo Fender
No to spit hairs but on the carter built quadrajet on my '79, the idle speed screw is low, on the passenger side of the carb.
Old Jul 2, 2002 | 11:54 AM
vettesite's Avatar
vettesite
The idle speed adjustment on my Q-jet carb is on the drivers side, toward the front of the carb, with a small spring around it.
[Modified by vettesite, 1:05 PM 7/2/2002]
Old Jul 2, 2002 | 12:49 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: carb question (Neo Fender)
that is the fast idle when the choke is on adjustment screw if you set the curb idle with that you must not have a working choke :chevy
Old Jul 2, 2002 | 05:24 PM
Larry B.'s Avatar
Larry B.
The screw on the passengers side is the FAST idle whenthe choke is on.
Old Jul 3, 2002 | 01:58 PM
03whitecoupe
Thanks to all who responded. My idle speed is now 600 and she runs like a dream. That's what makes this forum so great! :D :D
To carb question
