90 degree tach drive coupling
Old Sep 5, 2013 | 03:56 PM
lombardinh's Avatar
lombardinh
Cruising
Default 90 degree tach drive coupling
I own a 74 Corvette that had a tach cable problem. I ordered a new cable and a 90 degree adapter to change direction of connection to distributer. After hooking all up the tach did not work. It took about 45 minutes to figure out the adapter was turning the wrong way. I switched the drive side of the adapter to the grease fitting side. Now the cable was turning correctly and tach worked. Supplier said he never heard of this and had no other complaints from other customers. Has anyone else had this problem or ideas why I had to change direction of adapter. . Baffled Don
Old Sep 5, 2013 | 05:02 PM
edk136's Avatar
edk136
From the advice given here, I would get rid of the 90 degree adapter and re-clock the distributor. The adapter is known to cause a lot more problems with the distributor which may require machine work to fix. Search the threads here and find the instructions on how to re-clock the distributor. I'm assuming your old tach cable broke due to the sharp bend coming out the distributor, re-clocking it will fix this problem.
Eric
Old Sep 5, 2013 | 05:26 PM
Gordonm's Avatar
Gordonm
Ditch the coupler and put the dist in the correct way. They never had couplers from the factory.
Old Sep 5, 2013 | 05:37 PM
Mooser's Avatar
Mooser
My car had one of those on it, just seems to put un-needed load on the gears.
Probably not enough to make much difference being how little this gets driven but I pulled the dizzy and re-indexed, (also needed to help the timing, vac-can was hitting the intake)
M
To 90 degree tach drive coupling
