Anyone using these spacers for their monospring?
Old Sep 5, 2013 | 08:50 PM
rafalc's Avatar
rafalc
Default Anyone using these spacers for their monospring?
Im talking about these vertical front/back spacers that come stock with the 9 leaf.
https://www.paragoncorvette.com/p-35...pacer-kit.aspx
Wondering if I should use these with the new VBP spring. The fit is pretty tight, not sure if they would even fit....
Old Sep 6, 2013 | 08:22 AM
rafalc's Avatar
rafalc
Maybe I should rephrase the question....
SHOULD I use those spacers on my fiberglass VBP spring? .....if they even fit
Old Sep 6, 2013 | 08:33 AM
jb78L-82's Avatar
jb78L-82
My VBP 360 spring has been on the car SINCE 1986 and yes I did put those spacers in with the spring back then-just peeked under the car for a look.
Old Sep 6, 2013 | 10:41 AM
mrvette's Avatar
mrvette
My VBP 360 spring came with it's own spacers....one of which is about 3/4" thick, the others are thinner.....but I bought mine in '95.....
Old Sep 6, 2013 | 10:53 AM
tracdogg2's Avatar
tracdogg2
No, those spacers are only for 78-79 when using the 2 1/4 Gymkana spring in a stock 2 1/2 rear cover.
Mike
Old Sep 6, 2013 | 11:23 AM
jb78L-82's Avatar
jb78L-82
That's probably what I did in 1986 as well. My spacers probably came with the spring and yes one is bigger than the other as you described.
Old Sep 6, 2013 | 11:28 AM
rafalc's Avatar
rafalc
I think you guys might be thinking of the other spacers.....
Look at this link, item# 13023K. These are the ones I am asking about. No way in hell these would be 3/4"
https://www.paragoncorvette.com/corv...talog/c3/#38/z
Old Sep 6, 2013 | 12:00 PM
tracdogg2's Avatar
tracdogg2
Yep, those are the ones I'm talking about. In 78 (maybe late 77) Gm changed from a 2 1/4 wide spring with 9/16 mounting bolts to a 2 1/2 wide spring with 7/16 mounting bolts. The Gymkana option still used the 2 1/4 spring but on the 2 1/2 cover. Those spacers filled the gap on the front and rear of the spring. They won't fit the 9/16 bolts.
The GM service cover for 63-77 is the 78-79 cover.
Mike
Old Sep 6, 2013 | 12:05 PM
rafalc's Avatar
rafalc
Mike
Thanks Mike.
By the way.... the shock mount went in easy as pie. Alternating tapping with tightening really did the job. I installed the shock as well just like you recommended. Granted....the hole might have been worn a bit from the first shock mount but still, I should have never went crazy with that sledge hammer like I did.
To Anyone using these spacers for their monospring?
