Rearend Toe Out Alignment
Old Sep 15, 2013 | 07:28 PM
jnb5101's Avatar
jnb5101
rear toe-in has to be set to the center line of the car, not to the opposite side. did your guy do this, or wasn't he able to remove shims from both sides, so he took the easy way out and played with the side he was able to adjust.
Old Sep 15, 2013 | 07:37 PM
billcarson's Avatar
billcarson
do you have any pictures of the area?the rear wheels must track properly with relation to the front in addition to having the correct toe.not an area to fudge anything.
Old Sep 15, 2013 | 07:56 PM
Mike Ward's Avatar
Mike Ward
Originally Posted by gahaegele
Does this tell me I have something major bend on the left side???
Basically, yes.
Old Sep 16, 2013 | 12:08 PM
ignatz's Avatar
ignatz
Loop a big tight piece of string around all four tires, center the steering and describe what you are seeing.
