Input on BB fuel pump
Old Sep 12, 2013 | 10:16 AM
grumman41's Avatar
grumman41
Default Input on BB fuel pump
Currently getting ready to reinstall my LS5 engine back into the Vette...not sure if the stock mechanical fuel pump is sufficent for what I'm doing or if I need more flow-volumne.
The engine is close to stock other than a roller cam and three angle valve job/ cleanup here and there. I don't want to add a electric pump, trying to keep factory look.
The car will be used for street cruising-general performance driving. I guess my main concern is I don't want the engine leaning out do to lack of fuel.
Thanks, Kevin
Old Sep 12, 2013 | 10:35 AM
rponfick's Avatar
rponfick
GM would't steer you wrong. Stock sounds sufficient.
Ralph
Old Sep 12, 2013 | 11:13 AM
Mike Ward's Avatar
Mike Ward
You'd have to exceed stock HP by 200-300HP to cause the pump to run out of breath.
Old Sep 12, 2013 | 11:50 AM
Les's Avatar
Les
Ralph
When I was building my 427 many years ago I asked the same question. Somebody pointed out that my fuel pump was the same one used for the L-88. That was all I needed to hear. It's been more than adequate.
Old Sep 12, 2013 | 01:09 PM
roscobbc's Avatar
roscobbc
using stock pump for 489 cu in 528 hp with 950 cfm dp - it is fine
Old Sep 13, 2013 | 12:03 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
I'll disagree. Maybe a stock fuel pump will be ok for mild horsing-around on the street use but if you do any extended Bonsia's, she'll starve. I tried a stock pump on a pretty mild 396 Camaro (about 450-475 HP,..Holley DP 800,..dual plane) and she couldn't make it down the 1320.
If you plan any track time go to something like this:
http://www.summitracing.com/parts/ed...maro/year/1969
I like this one,..110gph (a stock pump flows about 30gph if that) and it only has 6 psi which means it won't over-power the needle-n-seat(s) of your carb.
Here's some good info on fuel pump requirements:
http://www.onallcylinders.com/2013/0...ions-answered/
...basically, at 400 HP it's time for the upgrade IMO, plus it will help overcome the stock fuel system which can be restrictive.
Old Sep 13, 2013 | 01:20 AM
illenema's Avatar
illenema
I replaced mine with a 110GPH mechanical, worked well.
Replaced with a high power electric with a bypass regulator, noticed instant improvement in throttle response, PITA to install buts its done.
Old Sep 13, 2013 | 01:26 AM
TimAT's Avatar
TimAT
I must be doing something wrong. I'm running a crate LS-7. That's the 454/460 that was "supposed" to be in the 1970, but GM killed it. I've added more cam, aluminum heads, currently running an 850 Demon, and I've also had a 2x4 Edelbrock carb setup with the stock 427 fuel pump and never had a bit of problem. And that includes some extended 5500 to 6000 trips.
Old Sep 13, 2013 | 07:52 AM
grumman41's Avatar
grumman41
Fuel systems and fuel flow is one of my weaker areas but I wonder if some of these cars in the 400 to 500 hp range (not running a rear electric pump) are a little short of fuel under a hard launch.
I'm going to run my engine on a dyno to check fuel pressure and AF ratio but in a car and under accelleration is very different.
Kevin
Old Sep 13, 2013 | 08:23 AM
70BBvert's Avatar
70BBvert
I'm running the stock fuel pump on mine as well with no problems. Not stock, but not 700HP either. I swear I could pull a house down in first gear
Jim
Old Sep 13, 2013 | 11:09 AM
73, Dark Blue 454
Jim
An inadequate fuel supply (pump) won't present itself in first gear. Run through the gears at 5500-6500 RPM for 12-13 seconds and see if she 'swallows the egg'. That's the only way to tell if your performance engine is receiving needed flow and PSI.
Also, somebody above said their 'throttle response' improved by upgrading to a bigger pump. The pump has nothing to do with initial throttle response; the fuel credited for "throttle response" is already in the fuel bowl(s) of the carb.
Again, an upgraded pump will supply fuel long after a stock pump has peaked out,..usually 6-8-10-12 seconds of WOT.
FWIW
Old Sep 13, 2013 | 11:15 AM
Les's Avatar
Les
FWIW
This spring I ran 11.37 @ just under 120 MPH, and stayed in it up to at least 125 MPH. It was still pulling like a mad dog when I let off to find a return lane. Not an egg in sight.
Old Sep 13, 2013 | 01:35 PM
70BBvert's Avatar
70BBvert
FWIW
Been there done that - shh Hasn't been a problem for me
Jim
Old Sep 13, 2013 | 08:18 PM
Ironcross's Avatar
Ironcross
all that's necessary and almost the identical set up LS-7 in my Red car....{11.4 at 120 mph Detroit Dragway}....have you ever looked at the tiny hole in the fuel nuts on the carb? ...put a L-72 pump on the car or its equivalent......
To Input on BB fuel pump
