Need help, Carb intake and headers
Old Sep 16, 2013 | 12:00 PM
psublett's Avatar
psublett
Default Need help, Carb intake and headers
have 78 L-82...been looking at Jegs. Price ranges are pretty far apart, want quality and best bang for my buck for what I have.
Also which header will give the best sound and performance?
Old Sep 16, 2013 | 12:26 PM
pauldana's Avatar
pauldana
I have been told many times...and now a believer, you can have any of the 2... but never all 3
1 Cheap, inexpensive
2. reliable, trouble free
3. high performance, speed, power
headers, make sure they have a large thick flange so you dont get leaks, make sure they are ceramic powder coated so they dont burn your plug boots.....
intake: is this a final mod? or is this the beginning of a major high performance build... if stock then the Edelbrock performer... but if this is just the beginning of a major high performance build, get the manifold that will work best with your final build rather than buying twice.
Carb... again, stock or major build... stock the Edelbrock 650 is great... major build??? also stock the Q-jet rebuilt is fine...
Old Sep 16, 2013 | 01:36 PM
TedH's Avatar
TedH
Stock q-jet intake will support most builds up to 400hp. Edelbrock Performer is pretty close to OEM (to clear corvette hood). I replaced my OEM aluminum intake with 3701 Performer because mine was weeping coolant back near distributor (porous).
If you have q-jet, aluminum OEM intake, I'd go with a coated (inside and out) set of full length 1 5/8" headers, true duals and turbo mufflers, good q-jet performance rebuild with jetting by reputable q-jet builder, dizzy recurve and reuse the OEM aluminum intake. This will be a good 50hp performance increase that you will feel.
Old Sep 16, 2013 | 04:20 PM
psublett's Avatar
psublett
thanks, not looking for a major build...something better than what I have.
It has side exhaust...and an upgraded cam (not sure what it has though)
looking for more pep and a bit more growl
Old Sep 16, 2013 | 04:33 PM
MelWff's Avatar
MelWff
try one of these systems along with a set of headers
http://www.summitracing.com/search/y...rmance-exhaust
Old Sep 16, 2013 | 06:06 PM
694speed350's Avatar
694speed350
With carbs spread bore intake rebuilt Q jet or holly 4165. Headers please run true dual exhaust not two into one into two.
Old Sep 16, 2013 | 07:04 PM
johnnyw's Avatar
johnnyw
I would really consider wraping the headers before you install them. It would be so simple and you won't regret it.
Old Sep 16, 2013 | 09:14 PM
psublett's Avatar
psublett
already have side exhaust
Old Sep 16, 2013 | 10:35 PM
scottyp99's Avatar
scottyp99
If you have the side exhaust, you really need the side exhaust headers. Something like this:
http://www.summitracing.com/parts/he...ette/year/1969
Scott
Old Sep 16, 2013 | 10:45 PM
psublett's Avatar
psublett
Scott
thanks Scott, can you elaborate as to why these specifically? What about intake?
Old Sep 16, 2013 | 11:13 PM
psublett's Avatar
psublett
also looking for a loud mean sound...read about sts baffles and Vettepack etc
what are your thoughts?
thanks
Old Sep 17, 2013 | 06:38 AM
scottyp99's Avatar
scottyp99
Well, if you take a look at where your engine is, and where your sidepipes are, you'll see that if you use a conventional set of long tube headers, it will be necessary to fabricate a 180 degree bend, followed by a 90 degree bend, in order for the exhaust pipe to line up with the sidepipe. I've seen 'vette's where people actually did this, and it's just plain ridiculous. As far as the intake, you can find Edelbrock 2101 intakes on ebay and craigslist for 50 bucks, if you hunt around.
Scott
Old Sep 17, 2013 | 07:59 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Hooker Max Flo's and call it a day.
Old Sep 17, 2013 | 10:13 AM
psublett's Avatar
psublett
Scott
Thanks again...and that intake would be an upgrade?
Old Sep 17, 2013 | 10:14 AM
psublett's Avatar
psublett
Thanks, any reason these over others?
Old Sep 17, 2013 | 10:34 AM
1977L48's Avatar
1977L48
I know we put a voodoo cam 60102lk in a 77 L82 with a weiand street warrior intake, and the hooker headers/ exhaust system on it with flow masters, alittle too loud for my taste but that little bit of work woke that thing up!! it was a rocket! and it would get 15mpg! we kept the Q-jet on it
Old Sep 18, 2013 | 10:00 PM
psublett's Avatar
psublett
Will sts baffle insert fit in my current side exhaust? I have no idea how it works but that's the sound im looking for
To Need help, Carb intake and headers
Old Sep 19, 2013 | 09:22 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Nope but they do have a loud, mean sound that you are looking for. They may be cheaper also.
Old Sep 19, 2013 | 10:22 AM
MelWff's Avatar
MelWff
Default Current side exhaust
No STS will not fit they are intended for the Hooker style side exhaust not the factory style you currently have.
Old Sep 19, 2013 | 10:24 AM
1977L48's Avatar
1977L48
go with chambered! mine shipped out Tuesday and should be here tomorrow! got me a weekend project now!
