Looking for some Crane cam info
Old Sep 17, 2013 | 07:21 PM
1427's Avatar
1427
Default Looking for some Crane cam info
Have a friend that has a big block cam that I need specs on. It's a older cam I believe. Number are.
R234/3335-2-12 BK 2236
Any info appreciated
Thanks 1427
Old Sep 17, 2013 | 08:56 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Thanks 1427
I'd recommend that you Google it... However, I do recall that Crane had a method of numbering which went like this: the 234 is the intake duration at .050; the 3335 is the lobe lift (.3335"), the 2 means that it has a dual pattern, and the 12 means that the lobe separation angle is 112 degrees.
Old Sep 17, 2013 | 10:08 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
http://www.hotrodders.com/forum/old-...ed-197203.html
Old Sep 18, 2013 | 06:06 AM
1427's Avatar
1427
Thanks guys!
To Looking for some Crane cam info
