1981 header question
Old Sep 21, 2013 | 08:37 PM
phinfan's Avatar
phinfan
Default 1981 header question
I have an 81 that im thinking about putting an exhaust system on from corvette central. Im trying to decide between part #323130 and the same system only its more symmetrical.
My question would be that by going to these headers it would make the smog pump inoperable, wouldn't it? If thats the case will that mess up my computer?
I guess I should have said my car is 100% stock at this point.
Old Sep 21, 2013 | 08:58 PM
SIXFOOTER's Avatar
SIXFOOTER
It will require deleting the AIR pump. If you have a bung welded in you can still mount the O2 sensor and the CCC system will still work fine. The bung should right below the flange on the drivers side
Old Sep 21, 2013 | 09:53 PM
maxmachz's Avatar
maxmachz
I got the CC system and it has the bung for the O2 sensor.
Computer has no clue of the AIR pump is there or not. I took mine off and plugged the holes in the headers / manifolds. Runs fine, no CEL. Also put a torque converter lockup bypass switch for in town driving and my mileage has gone UP.
Old Sep 21, 2013 | 10:53 PM
phinfan's Avatar
phinfan
Thanks for the reply, how is the quality of that system, how has it worked, can you tell a difference?
Old Sep 22, 2013 | 09:06 AM
Jig A Low's Avatar
Jig A Low
you can always get the headers and have the AIR injection tubes welded into them, then you can run the air pump and keep the car running per the factory.
I also got the corvette central dual exhaust system for my car, fits good with only minor tweaking, I put long tube headers on the car and the system was built for stock manifolds so I had to cut the pipes off enough to allow for the headers, not a tough job.
Old Sep 22, 2013 | 11:42 AM
maxmachz's Avatar
maxmachz
I thought the quality was great. It bolted right up with no hassles at all. Sounds nice, it is quiet with the Magnaflows, just a nice low mellow sound, not obnoxious at all.
Performance wise I could not tell. Short of going to a dyno or track and recording baseline numbers and then going back after a change is made there is no real way to tell for sure.
Most guys put stuff on / change things and swear it runs better / faster but really have no facts on it.
Old Sep 22, 2013 | 05:25 PM
phinfan's Avatar
phinfan
Cool, were the headers coated?
Do you recommend them versus the long tube?
Old Sep 22, 2013 | 06:30 PM
maxmachz's Avatar
maxmachz
I did not get the headers, I got the complete system that bolted up to the stock manifolds. #323100
To 1981 header question
