Dome light 1977
Old Sep 23, 2013 | 03:54 PM
Ryder12's Avatar
Ryder12
Default Dome light 1977
I just had my 1977 corvette painted and 2.5 months later I got the car back and the dome light stays on for 30-60 minutes after the doors are shut. I understand that the timer is taped to the wiring harness between the tac and the speedometer how do I get to it ??
Old Sep 23, 2013 | 03:59 PM
MelWff's Avatar
MelWff
try this video
Old Sep 23, 2013 | 08:56 PM
Ryder12's Avatar
Ryder12
That is not a 1977 I don't have a glove box
Old Sep 24, 2013 | 06:20 AM
nz corvette's Avatar
nz corvette
Hi, you have to lift the dash pad which is not to much of a problem in warm weather
There is an alloy cylinder that is your dimmer relay switch, you can remove this completely and connect the 2 ends which means you open the door, interior lights on shut door it's off
(that's what I did on my 77 because of a power drain)
cheers Dave
Old Sep 24, 2013 | 06:53 AM
Ryder12's Avatar
Ryder12
Thanks that is what I will probably do
To Dome light 1977
