18x8 rims
Old Sep 25, 2013 | 12:47 AM
svmagnum's Avatar
svmagnum
Default 18x8 rims
Hello Great people of this forum. Need some help with rims.
Found rims on ebay that I really liked and need to know if they'll fit my car. I have 75 vette. Below is copy paste of wheel spec. Will they fit? Or do I have to do some modifications and if yes then which. Thanks for help
WHEEL SPECS
RIM DIAMETER: 18 inches
RIM WIDTH: 8 inches
BOLT PATTERN: 5x120 mm
OFFSET: 40 mm
CENTER BORE: 72.5 mm
Old Sep 25, 2013 | 09:42 AM
oldalaskaman's Avatar
oldalaskaman
40 mm is i 1/2 inches, you'll need adapters
Old Sep 25, 2013 | 12:30 PM
svmagnum's Avatar
svmagnum
What kind of spacers? Sorry don't know any thing about fitment of rims
Old Sep 25, 2013 | 12:48 PM
ddawson's Avatar
ddawson
Those look like BMW specs.
Old Sep 25, 2013 | 01:02 PM
svmagnum's Avatar
svmagnum
Yup they are. From what I researched BMW rims fit. Even though they have slightly different pattern
Old Sep 25, 2013 | 02:31 PM
MelWff's Avatar
MelWff
Default spacers
the wheels have 40mm of positive offset, typical corvette wheels have offsets in the low negative range, thus a spacer to push the wheel further out. Here is a link explaining offset
http://blog.tirerack.com/blog/tire-r...-is-rim-offset
Old Sep 25, 2013 | 03:44 PM
svmagnum's Avatar
svmagnum
Is it bad or unsafe to use spacers? And how big the spacer has to be?
Old Sep 25, 2013 | 05:09 PM
donyue's Avatar
donyue
WHEEL SPECS
RIM WIDTH: 8 inches
OFFSET: 40 mm
Hi Svmagnum,
I think you will have some overall fitment issues with those wheels. I have wheels with the following specs and they fit with no issues. It might be wise to stick with something similar to be sure. I believe you can adjust the offset a little up to 5 inches, but you need to be careful to avoid interference.
RIM WIDTH: 8 inches
BOLT PATTERN: 5 x 4.75 inches
OFFSET: 4 inch
CENTER BORE: unknown.
Old Sep 25, 2013 | 06:23 PM
ddawson's Avatar
ddawson
If you want to do the math
http://www.rimsntires.com/specs.jsp
I'm not a fan of spacers.
Old Sep 25, 2013 | 09:01 PM
svmagnum's Avatar
svmagnum
Don't really understand what to look for
Old Sep 25, 2013 | 10:38 PM
3JsVette's Avatar
3JsVette
Do a search in this forum using the word "adapters". There is lots of reading on this.
If you are looking for 18x8 wheels you should try to find wheels with a 4" backspace and a 5 on 4.75 bolt pattern. Then you won't need adapters.
Good luck in your search.
To 18x8 rims
