Amatuer owner.. t56 install
Old Sep 25, 2013 | 12:10 PM
Bigeddie's Avatar
Bigeddie
Default Amatuer owner.. t56 install
hey guys just found a t56 reaaaly cheap...i had contemplated of making my 79 automatic into a 4 or 5 speed car or an automatic with verdrive but this beautiful 6 speed came along after months of hunting craigslist....i was just wondering what will i need to convert from automatic to using the t56... i know i can buy a kit from online but all of them say they are for 5 speed...i need to know exactly what i need in a list form if possible and more or less price. i am that weird kid that while in college i decided to get a corvette so money is my biggest hurdle right now but if you guys have parts or can give me an idea what everything will cost i can start saving or buying parts a little at a time.. thank you guys in advance and have a nice day
Old Sep 25, 2013 | 12:12 PM
Bigeddie's Avatar
Bigeddie
by the way meant amateur in title..hey i might get more people coming in saying this kid really needs help
Old Sep 25, 2013 | 12:29 PM
MIKE80's Avatar
MIKE80
What did the T56 come out of? Do you have any other parts with it besides just the transmission?
Old Sep 25, 2013 | 01:51 PM
Bigeddie's Avatar
Bigeddie
came out of a 95 z26 lt1 engine..just tranny.. he was supposed to send bell housing clutch and sensors but have not received them i might have to drive three hours away from my house to collect the money and gas on top if he doesnt send it.. im a big guy so ill see lol as of right now i have only tranny
Old Sep 25, 2013 | 02:12 PM
MIKE80's Avatar
MIKE80
I installed a LT1 T56 from a 94' Trans Am. I had a nice clutch and flywheel setup from my original 4 speed, so I converted the trans to except it using a custom kit that came with a bellhousing and hydraulic throwout bearing.
Your best bet is to get as much of the stock parts as you can, bellhousing, clutch slave cylinder, etc. You will need a conversion flywheel for the 2 piece rear main seal engine you have http://www.specclutch.com/conversion_combos/view/2
For the clutch master you can get one for an 85' Chevy pickup and search the forums, others have threads on installing it http://www.autozone.com/autozone/par...er=734863_0_0_ You will need to get a line made up to connect the master with the slave cylinder. You can modify your existing crossmember. I bought a custom crossmember from Bowtie Overdrives. 82' vette driveshaft, or have your current one shortened and balanced. Not sure if you have the same slip yoke as the 82' vette. The rest is probably close to what I've done in my thread.
Or you can convert the trans with the same kit I used. Here's the thread I made on the swap.
http://forums.corvetteforum.com/c3-t...gs-list-7.html
Old Sep 25, 2013 | 04:31 PM
Bigeddie's Avatar
Bigeddie
thanks thats a start... by the way sweet car..wooow jus wow beautiful car
Old Sep 25, 2013 | 06:14 PM
MIKE80's Avatar
MIKE80
Thanks Take your time, save your money for each project along the way. To start with, focus on making sure it's safe to drive, brakes, steering, suspension, etc.
I did most everything all at once while I had the frame out. Took me 7 years to build it the way I wanted it and get it back on the road.
Old Sep 28, 2013 | 05:40 PM
Bigeddie's Avatar
Bigeddie
funny you say that my brake light started coming on when i brake..im hoping its just needing to bleed brakes and get all air.dont want to mess with the proportioning valve or that thing all those lines go to.. i just redid my front suspension bushings and welded the a arm "rails" that were coming apart on the driver front wheel....also i need to smog it soon so after that i want to learn how to tune a quadrajet and recurve my distributor... eventuallyyears from now ill go into engine get a paint job... only upgrades ill be doing is recurng dizzy,tuning carb correvtly and maybe have a dual exhaust made with electric cutouts out to side pipes(i have side pipes just never installed), and of course the t56...
Old Sep 28, 2013 | 05:42 PM
Bigeddie's Avatar
Bigeddie
maybe change the intake manifold too sine i have an edelbrock air gap without egr hole in my garage.. and no its not the rpm airgap its the performer air gap
Old Dec 29, 2013 | 08:34 PM
Bigeddie's Avatar
Bigeddie
finally getting to it after tranny gave out.... i will be getting the 85 1 ton master. i think i will be using the stock slave cylinder from the t56 if im able to. now do i what kind of clutch do i need and throw out bearing. i know i have to buy one of those conversion flywheels because i have 2 piece rear main seal. please help guys
Old Dec 30, 2013 | 08:54 AM
MIKE80's Avatar
MIKE80
If you are keeping the stock Camaro clutch, use the conversion flywheel with any clutch and throw out bearing for the year Camaro the trans came out of. Spec sells a conversion flywheel and clutch, so does CenterForce. I had a shop check the balance on my flywheel for neutral balance before I installed it. Call BowtieOverdrive and tell them what your conversion is and they should be able to get you the correct crossmember. Also, some guys use G-Force crossmembers as another option, but not sure if they need modifications.
Old Dec 30, 2013 | 01:54 PM
Bigeddie's Avatar
Bigeddie
mike it doesn't make sense?!??you mean if im using the camaro slave cylinder use any clutch? or do u mean if im using the 95 camaro slave ,fork, and thowout bearing to use any clutch that was supposed to be used on the year that camaro the tranny came out of. granted i do need to buy the aluminum flywheel correct?no need for aluminum flywheel but yes on the conversion flywheel correct? my head is spinning right now got less than a month to do this before school starts and before i could go pply for a job lol
Old Dec 30, 2013 | 02:33 PM
MIKE80's Avatar
MIKE80
Assuming that you are using the 95' Camaro slave, fork, bellhousing, and throw out. Get the Spec or Centerforce conversion flywheel. The rest of the clutch setup can be 95' Camaro parts. You can call Spec or Centerforce Tech Support to verify the part numbers for your conversion.
http://www.summitracing.com/parts/ctf-700107
Old Dec 30, 2013 | 02:46 PM
Bigeddie's Avatar
Bigeddie
thanks mike your the best my man. if i could buy you a beer or two i would
Old Dec 30, 2013 | 03:19 PM
MIKE80's Avatar
MIKE80
No problem.
Old Jan 1, 2014 | 02:04 PM
Bigeddie's Avatar
Bigeddie
hey mike what do you think about a short shifter
Old Jan 1, 2014 | 02:35 PM
cv67's Avatar
cv67
St. Jude Donor '05
I have the old B and M ripper think the Hurst is smoother
To Amatuer owner.. t56 install
Old Jan 1, 2014 | 08:25 PM
MIKE80's Avatar
MIKE80
I have the stock shifter with no stick, but I decided to get and modified a Hurst shifter to come through the stock console location and it shifts very nice. I'll sell the stock shifter if you decide to keep cost down and need one.
http://www.summitracing.com/parts/hu...rd?prefilter=1
Old Jan 2, 2014 | 10:05 PM
Bigeddie's Avatar
Bigeddie
do i get 79 c3 pilot bushing or the one for the 95 camaro
Old Jan 2, 2014 | 10:17 PM
Bigeddie's Avatar
Bigeddie
also will i be using stock starter or one from the camaro i got the tranny from
