BROWN WIRE GOING TO ALTERNATOR???
Old Jul 3, 2002 | 07:57 AM
OkeeGuy's Avatar
OkeeGuy
Default BROWN WIRE GOING TO ALTERNATOR???
the plug on the top has two wires going to it...
a fat red one and a smaller brown one...
where does the brown go????
Old Jul 3, 2002 | 08:09 AM
mrvette's Avatar
mrvette
Default Re: BROWN WIRE GOING TO ALTERNATOR??? (SIGNGUY)
Brown wire should go to one side of the idiot light sayng bat or alt or gen on the dash.....it's red.....should light if the key is on and engine still....
indicates no alternator output....if it's not hooked up the alternator will not put out untill engine is revved up quite a bit....3000 rpm's or so...
GENE
Old Jul 3, 2002 | 08:38 AM
OkeeGuy's Avatar
OkeeGuy
Default Re: BROWN WIRE GOING TO ALTERNATOR??? (mrvette)
hhhmmmm....then i doubt that i really found my problem...
ie...my other post about my alt problems...
but it sure seems like i did :confused:
what do you think about that gene????????
thanx
To BROWN WIRE GOING TO ALTERNATOR???
