That is an oil pressure switch, to feed an oil pressure idiot light or an electric oil pressure gauge. It looks like somebody put together a tee fitting out of hardware parts because on the other side of the tee is the typical oil line that feeds a mechanical oil pressure gauge. You'd have to figure out whether your dash gauge is mechanical or electrical to diagnose the problem. If mechanical, the the needle is probably stuck. If electrical, unplug the connector on the sending unit, clean it and make sure the terminal is making a good connection to the wire.
Assuming you have a stock 73, you would have a mechanical oil pressure gauge. The part in the picture looks like a electric oil pressure switch. So is your set up stock or what?
Thanks...I believe I have a mechanical oil pressure gauge. Any suggestions on how to unstuck the needle or do I need to replace the entire gauge?
Do you have an electric fuel pump or an oil idiot light setup?
That would be used to shut off the fuel pump if the oil pressure isn't there, in this case its used as a safety mechanism to turn of the pump in case of an accident or stall of the engine.
The part going the other direction away from the electrical switch seems to have the nut and Ferrel setup for the nylon tube that goes to a mechanical pressure gauge.
Unfortunately my car has been messed with by immature p.o. and Im not sure what he did..I know I have a mechanical oil pressure gauge and the black wire attached to the oil pressure switch is connected to another switch unit with an hose cut off..I kinda want to take that old stuff off
well I can see a rubber hose cut off on the other end on the switch...maybe it was used for that safety purpose at one time...I dont think is working nor is connected to anything anymore.
Everything else looks stock to me...Im not expert though
Thanks for all your help.
That rubber hose cut off on the other end would really be a nylon tube and it may have melted closed.
If your not using that rubber hose/nylon tube to feed your gauge then by all means remove the broken hose/nylon tube and plug that pipe because if that hose lets go you will loose all of your oil and seize the engine.
That nylon hose is supposed to into the car to a mechanical gauge. Looks like someone put in the wrong electrical sending unit and may have tied it to a late model electric oil pressure gauge. I saw a post about someones gauge stuck at 30 and maybe that was you with this funky setup. You would need the correct sending unit matched to the correct late model gauge and you can use an electric gauge in your car if wanted.
Those tubes work well for years if unmolested. But recently a guy had his clock changed on his 71, kinked the tube in the console and the tube broke, he lost all the oil into his rug in the car and seized the engine. Very expensive clock repair........
mysixtynine,
perhaps I wasn't very good at explaining n describing..:
On the right of the copper adapter I have a copper line that goes through the firewall and connects directly to the mechanical oem oil pressure gauge.
On the other side the black wire with the blue connector to the switch is attached to some other switch and a cut off hose...here's a picture:
I hope this helps explain myself..sorry for the confusion...what the eck is this?
I dont know what year you have but if that is connect to a switch on the oil pressure port it was meant to control something that used vacuum based on the presence or lack there of oil pressure.
I cant seem to orient myself to the latest picture where is that?
I looked at the 73 stuff i can find and I don't see that anywhere on the vacuum diagrams and the oil pressure sending stuff just doesn't look stock to me. It looks like its mounted by your #1 body mount, I just cant imagine what would need to sense oil pressure and then operate a vacuum source. I could see temperature but not oil... Just escapes me.
that oil pressure sending unit(electric) is not stock.it was an after thought by a PO. the small vacuum pod mounted at your #1 body mount is not original either.i would remove it and while your at it consider re plumbing the mechanical oil line to your gauge(as copper line will break).you can go with the original plastic line and fittings or you can go with an auto meter flexible ss line with the fittings on the line which will mount to your factory gauge.you may have a clogged copper feed line to your gauge or some old dried up oil in the gauge,you would need to remove the gauge and check.hope this helps you.
