power steering control valve
Old Sep 27, 2013 | 10:17 AM
commander_47's Avatar
commander_47
Default power steering control valve
Not my area of expertise.....but a rather frustrating issue.
I did an exchange a couple years ago with a reputable vendor for a rebuilt power steering unit including the valve.
Well, I drove the car yesterday and everything went great. Ran like the beast it is. I made a couple minor lash adjustments on the steering box to loosen it up a bit and then put the car in the garage.
Woke up this morning to a huge puddle of PS fluid on the floor and fluid Drip drip drip drip dripping from a PSCV with less then 5o miles on it.
I was able to find a repair kit at Advance Auto that only has the seals for $12:00. I believe one of them is obviously blown out.
Any suggestions on which seal to look at?
Does the entire thing have to be torn down?
Can I just do the six seals...anything possible while on the car?
Old Sep 27, 2013 | 10:45 AM
MelWff's Avatar
MelWff
read/ watch these links
http://community-2.webtv.net/MATTGRU/Quickwaytoreseal/
Old Sep 27, 2013 | 11:03 AM
commander_47
Wow.....that is exactly what I need.
This forum is great!!!!
Thanks for the link
Old Sep 27, 2013 | 04:12 PM
spinadog's Avatar
spinadog
Stop right there.
I had exactly the same issue with mine (not even 8 weeks ago), and the same circumstances (new PS control valve). It was a blown return hose, yet at first, I blamed the PSCV. Those replacement hoses are junk, and very weak. Mine had split up high, and was pouring down the hose. It looked exactly like the PSCV had blown a seal.
Jack the car up on stands, and move the steering manually left-right. You'll pump up the ram and quickly see where it is leaking.
I hope you have a nice surprise like me! $3 later and fixed.
Old Sep 28, 2013 | 10:24 AM
Mr.Green's Avatar
Mr.Green
I patched my PSCV up two times before I gave up and went with the Borgeson option. I have a detailed thread on it if you get fed up with the PSCV constantly leaking.
Old Sep 28, 2013 | 04:06 PM
commander_47
I tell you, something is going to have to give.
I'm beginning to think that black cloud over my head is PSCV.
So this thing is a BRAND NEW rebuild from a reputable vendor. Made in America, Gates hoses, first class. Has less than 100 miles on it.
Went out to go to work with it, and under the car is a huge puddle of Power Steering fluid.
I traced it to the PSCV.
To make a long story longer, I got a rebuild kit from Advance Auto. Took it apart on the car without removing the ball stud since all this is NEW.
Well, guess what? The O ring surrounding the main body was broken. A small roll of it had not been in the groove when it was torqued together.
No problemo. I got it apart and back together. Crawled under with a flashlight to make sure that all the surfaces were flush like they are supposed to be and then torqued the nuts to 60 lbs.
I then started the car to adjust the valve. All was going fine until suddenly, and I mean suddenly, like an explosion, hot power steering fluid spewed into my face and all over.
The fluid was under pressure and went everywhere, there was a ring of fluid as it came out around the ball joint and where the two halves meet.
This time I took the whole valve off, and took it apart on my bench. Low and behold, a huge chunk of the seal on the big ring was blown off.
Well, I went back to Advance Auto, and they are making good on the kit. I get a new one tomorrow.
But any ideas what is causing this?
Old Sep 30, 2013 | 08:34 AM
commander_47
I will tell you, this power steering valve is one POS.
I rebuilt it agin, and I am absolutely positive it is correct.
I started the car and it instantly spewed hot power steering fluid from under the ball joint.
I am going manual and convert this to a a Borgeson as money becomes available.
Old Sep 30, 2013 | 09:33 AM
wombvette's Avatar
wombvette
You just pinched the seal when you installed it. Build it right and it will work.
Old Sep 30, 2013 | 09:51 AM
commander_47
yes, I thought I might have done that the first time, so I was really careful the second time and took it all the way out and rebuilt it on the bench.
There were a lot of rust spots on the interior parts, including the valve. I honestly believe that is what is causing this. I cleaned them all up and replaced what I could, but was still rewarded with a face full of hot power steering fluid the second time.
I have always just replaced these valves in the past. And this is what I did this time.
The steering isn't all that hot anyway. In fact, it kind of sucks. I have all new bushings and ball joints, rebuilt box, new piston, etc. It's all new.
I have been scouring the net for a good deal on a Borgeson box and found this site and ordered the kit. Hey, that's what plastic is for right?
http://mudflaps.com/i-9745314-borges...FcJj7Aodxy8APA
Old Sep 30, 2013 | 12:10 PM
wombvette's Avatar
wombvette
Sounds like the seal was in backwards.
Old Sep 30, 2013 | 02:22 PM
commander_47
I tell ya, I always worry about stuff like that. I have definitely done bonehead things like that before, but not this time unless the link is wrong.
I did this valve twice. The second time I was totally **** about it.
I printed these instructions and followed them exactly. Even have them down next to the valve in my shop.
Check picture 43. This is exactly how I did the valve. Could this be wrong?
http://www.cssbinc.com/images/ads/ho...structions.pdf
Old Sep 30, 2013 | 04:11 PM
hugie82's Avatar
hugie82
Some of those parts looked pretty pitted from old age. Some strength was definitely compromised but hey, third time is the charm .
I'm watching this close because I know my time is coming soon to tear into the control valve and lines...
Old Sep 30, 2013 | 07:00 PM
commander_47
The main power piston, steering box and lines are all new. It is only the valve I seem to be having trouble with.
I will make you a great deal on this stuff if you are interested. I ordered a Borgeson box.
PM me and I'll send you pics and whatever.
Old Sep 30, 2013 | 11:51 PM
wombvette's Avatar
wombvette
I dont see anything wrong with the instructions, but I build it inside the head unit. Much easier to keep it stacked up correctly.
To power steering control valve
