I removed the intake manifold so that I can reseal it and when I did some anti-freeze moved about and now I can see that it is in the heads/valves and probably in the hole for the distributor.
How can I get rid of the anti-freeze that is in the heads/valves?
Put engine back together, pull spark plugs, turn over engine until water quits coming out of the spark plug holes. Change oil. Drive car for 100 miles, then change again. That's what I have done in the past.
I agree 100%. When I change the intake manifold or gaskets, I use a 1/4'' hose down the thermostat housing and run it down into the heads in order to syphon out as much fluid as possible, this way I don't have to drain the radiator and I don't get fluid into the oil. If you do it another way, be sure to drain the oil. Bad things happen if you mix coolant and oil and then start the engine. Good luck on your project.
Back up a bit. How much coolant are we talking about? A tablespoon in each intake port or the whole top end full of coolant? Use paper towels and soak up anything in the intake ports first then pull the plugs and crank it over to get any coolant out of the cylinders. Change the oil to get any coolant that got into the pan. A cup of coolant is not good by any means, but it's not a disaster either. The real problems are when the coolant hits hot oil in a running engine. The resultant milkshake is death to bearings. You pulled the intake so (obviously) the engine was not running. Not running the coolant will fall to the bottom of the pan under the oil and not mix easily.
thanks for the replies....I tried to get a rag in there but its difficult to get much out.
I drained the oil out - coolant came out first. Then I removed the spark plugs. Nothing came out of any of them. I still have some in the heads. the intake and carb are still off so I am not in a position to fire it up soon.
Can I just rotate the engine at the crank bolt to get the coolant to go somewhere else?
My main thing is that I don't want to ruin anything by having this coolant sit in there.
