bbc headers
Old Oct 25, 2013 | 10:19 PM
mvette76's Avatar
mvette76
does anyone have a pic of your 2 1/8 hooker super comps collector at ride height
Old Oct 25, 2013 | 10:22 PM
Dr L-88's Avatar
Dr L-88
2025 Corvette of the Year Winner- Modified
2024 C2 of the Year Winner - Modified
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
How 'bout a set of these Bill Thomas headers......................
Old Oct 26, 2013 | 12:49 AM
Rebelrob's Avatar
Rebelrob
Originally Posted by Stu's81
When you dent them does the coating come off?
No. Used a rubber/plastic hammer or a piece of wood.
Old Oct 26, 2013 | 12:55 AM
RickyBerg's Avatar
RickyBerg
The car is quite low and in this Picture the suspension is quite compressed due to a depression in the track.
The lowest part of the system is where the exhaust lay below the X-member for the gearbox.
Since the primary tubes are so long i didnt want to add a to steep "S" bend straight after the collector to make it fit in the holes of the X-member.
Im pulling the Engine and gearbox this Winter and will modify the X-member to get the exhaust a bit higher up.
//Ricky.
Old Oct 26, 2013 | 06:12 AM
roscobbc's Avatar
roscobbc
Before I took it to have exhaust system made up. Car has standard height F41 suspension - tyre are 27" tall, so this is more or less the factory ride height. Hooker 2 1/8" Super Comps.
Old Nov 9, 2013 | 03:08 PM
mvette76's Avatar
mvette76
picked up some used 2 1/8 hooker super comps on ebay hope they work for me! my front sits kinda low
Old Nov 9, 2013 | 03:29 PM
RickyBerg's Avatar
RickyBerg
My advise when using the Hooker Supercomp 2-1/8" on a low car is..
Get rid of the flanges between the colector an the reducer by welding the reducer direct to the collector.
Next thing is to cut out a section of the collector and replace with a 45-degree 3,5" bend to get the exhaust to line up with the holes in the transmission x-member.
This will help a lot with the ground clearense issue.
