C3 transmission change
Old Sep 29, 2013 | 10:36 AM
NOsburn's Avatar
NOsburn
Default C3 transmission change
Had a recent minor engine fire in our 1979. Will probably rebuild the engine as it has minimal miles on it. Would like to change the automatic to newer one that has an overdrive. Is there one that is the same length and same output shaft splines?
Old Sep 29, 2013 | 11:47 AM
DRIVESHAFT's Avatar
DRIVESHAFT
200 4r is about the same length, and has the same splines.
The trans mount location is further back, but you can either modify your crossmember if you have metal working skills, or you can buy an aftermarket crossmember designed for the swap.
Old Sep 30, 2013 | 08:15 AM
NOsburn's Avatar
NOsburn
Thanks for the tip. I think we will look for a 200 and go that way.
Old Sep 30, 2013 | 01:47 PM
mrvette's Avatar
mrvette
it is NOT a 200, it IS a 200 4r, a 200 is a weak 3 speed trans....it's basic setup was used and toughened up a bit and the o/drive added....you want one from a Monte Carlo outta the 80's....
when you rebuild it, you want to add a TRANS GO shift kit....
when you get it in the car, we can help you with the lockup converter wiring,.....
Old Sep 30, 2013 | 02:23 PM
bluedawg's Avatar
bluedawg
200 4r or 200r4? Not trying to be a smart ***, just curious if I've been wrong on the name
Old Sep 30, 2013 | 02:25 PM
bluedawg's Avatar
bluedawg
Aw crap. I just googled it and of course I was wrong. Damn it.
Old Sep 30, 2013 | 07:04 PM
NOsburn's Avatar
NOsburn
Thanks, everyone. Debating on putting newer engine in and leaving tranny alone or dressing up engine and replacing tranny with 200 R4. Thought taller 1st gear and OD would be nice.
Old Sep 30, 2013 | 07:48 PM
Blue79's Avatar
Blue79
The 2004r in a '79 is an easy swap as the bolt-in cross member does not have to be changed or modified. Just take off(unbolt) the bracket for the TH350 tail mount and notice that the holes drilled in the cross member line up with the rear mount on the 2004r. You'll have to read up on the correct set-up for the TV cable to carb on say,.. the Bowtie Overdrives web site for clarification. The speedo gear may have to be changed but the cable hooks right up. I gotta say, it's like having a new car again with the overdrive in. Good luck with whatever you do.
Old Sep 30, 2013 | 07:56 PM
briankeery's Avatar
briankeery
FWIW I found one this summer and will be rebuilding over the winter. Will get all necessary parts from BowTie Overdrives and have it ready to go hopefully next spring. I found mine for $200.
Old Sep 30, 2013 | 08:45 PM
donnie1956's Avatar
donnie1956
2004R is the easiest swap. You don't have to change anything with the crossmember. Just remove the tranny mount plate and reuse the rubber upper mount. I have done it a couple of times on my 78.
To C3 transmission change
