1979 Power Steering Leak
Old Sep 30, 2013 | 01:36 AM
Hideki's Avatar
Hideki
Default 1979 Power Steering Leak
When inspecting underneath the car I noticed a ton of built up grime on the power steering valve. I cleaned it all off, and I was thinking it must be the lines (cause they hang pretty darn low and I was assuming the previous owner/s probably smacked something) But the lines don't appear to be leaking. I noticed a tiny drip coming from a hole on the bottom of the valve, it looks like it's supposed to have some fitting. All the valves I found online have a zerk grease fitting where that hole is. My question is, would power steering fluid be leaking from that grease fitting? I mean, I'm going to get the correct fitting for that, but would that potentially solve my PS fluid leak issue, or is that missing fitting another separate problem...
Old Sep 30, 2013 | 02:23 AM
Haggisbash's Avatar
Haggisbash
If PS fluid is leaking from that hole, it is likely that the seals inside the other end of the valve are leaking. Although they fit a grease nipple at that point you need to be very careful putting extra grease in there because you could force it into the other end where the PS fluid circulates.
