Intake Gasket
Old Oct 2, 2013 | 10:09 AM
gahaegele's Avatar
gahaegele
Default Intake Gasket
What would cause the gasket to be forced out from between the intake and the block?
Thanks!
Old Oct 2, 2013 | 10:44 AM
1977L48's Avatar
1977L48
excessive crank case pressure. are you running a PCV valve? to a constant vacuum port?
Old Oct 2, 2013 | 10:51 AM
MelWff's Avatar
MelWff
Is this a recent install of an intake manifold or it has been there for years and this is something new?
Old Oct 2, 2013 | 02:07 PM
gahaegele's Avatar
gahaegele
I do have a PCV valve install and it does have vacuum to it. I am not sure if it is constant pressure. I believe that it is connected to a thermo vacuum switch (I am currently 2,000 miles away form the car).
I have had the 77 for less than a year, I cannot say when the gasket was replaced but top end work was performed by the PO.
Old Oct 2, 2013 | 02:39 PM
MelWff's Avatar
MelWff
So it could have simply slipped or been squeezed out when the PO installed it?
To Intake Gasket
