JUST DROPPED A BUILT SMALL BLOCK INTO MY 82' AND CANT GET THE TEMP GAUGES TO WORK. STARTING WITH THE COOLANT TEMP. I KNOW THE GAUGE IS GOOD , DID SOME RESEARCH AND WATCHED A WILCOX VIDEO. ITS GOOD. JUST NEED THE RIGHT SENSOR TO STICK INTO THE ENGINE BLOCK. SOMEBODY STEER ME IN THE RIGHT DIRECTION TO PURCHASE ONE. I BOUGHT ONE FROM ECKLERS AND ONE FROM LOCAL AUTO PARTS STORE. BOTH MAKE IT READ THAT ITS GROUNDED OUT. PEGGED 250-260, IF I UNPLUG IT THE GAUGE FLOATS BACK TOWARD 100.
nOW MY ONLY THING IS I REMOVED THE ECM AND MOSTLY ALL ELECTRONIC CRAP FROM THE CAR. REPLACED FUEL INJECTION WITH A HOLLEY CARB. IS IT POSSIBLE THAT THE ORIGINAL SENSOR WENT TO THE ECM FIRST THEN THE GAUGE? SO BEING IF I GET SAY A SENSOR FOR SOMETHING PRIOR TO THE COMPUTER AND FUEL INJECTION CAR IN 82, SAY 80 BECAUSE THE GAUGE SHOULD STILL BE THE SAME, WILL THAT WORK?
