Witch brake pads?
Old Oct 2, 2013 | 10:26 PM
jbaron's Avatar
jbaron
2017 C3 of the Year Finalist
Default Witch brake pads?
What pads would be the right choice for my 74 stock Vette? Different parts stores offer different pads. Organic vs semi met vs ceramic.
Old Oct 2, 2013 | 10:39 PM
MakoJoe's Avatar
MakoJoe
Organic pads are the dirtiest and are old school,
Semi Metallic offer better stopping power and heat dissipation
Ceramic pads do not offer the best heat dissipation and on old style Rotors may eat into them faster.
My choice would be the Semi Metallic pads on an older car like the Corvette. because it is heavy and
here is a link and some info from that link
http://brakeperformance.com/
The Difference Between Semi Metallic and Ceramic Brake Pads
When deciding what brake pads are best for your vehicle, there are many factors to consider. The type of driving, weight of your vehicle and what is recommended by the manufacturer. Premium semi metallic brake pads are perfect for all light, medium to heavy duty cars, trucks, and SUV's. This type of pad is highly recommended for heavy work trucks, towing applications, performance vehicles, European vehicles and any vehicles experiencing warped brake rotor/discs due to excessive heat. These pads are manufactured with a high temperature fade resistance and a high friction level. They are simply the best pads for handling high heat and providing noise free braking. Ceramic brake pads are ideal for medium to light duty US Domestic, Japanese/Korean, Cars, Trucks and SUV's. These Pads are designed to wear longer and have less brake dust than the semi metallic pads. Ceramic pads are NOT recommended for heavy cars, trucks, SUV's or performance vehicles because they do not have a high temperature fade resistance and could warp rotors because of the heat factor. Both types of pads will give you great stopping performance and the information provided hopefully will help you make the correct decision.
Old Oct 3, 2013 | 06:05 AM
terrys6t8roadster's Avatar
terrys6t8roadster
my 68 with manuel brakes Wilwood caliphers Hawk HP pads and carbonized rotors requires less pedal effort than my 69 power brake all stock brake system. look at either Wilwood or Hawk pads. they have charts to help pick out pads for your type of driving. luck to you. TR
Old Oct 3, 2013 | 09:35 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Take a look at the Carbotech 1521, I will be happy to help you call me direct at 216-780-8825 and save 5%.
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound's excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
F $139 R $139
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Oct 3, 2013 | 09:37 AM
Mike Ward's Avatar
Mike Ward
Organic.
Old Oct 3, 2013 | 09:51 AM
1977L48's Avatar
1977L48
I had organic, loved them, but they only lasted about 6 months, they stop GREAT! very dirty tho. I tried ceramic and they last forever but my breaking suffered, took more effort to stop.
Old Oct 3, 2013 | 11:08 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I use organic and haven't had any issues, ever, for street driving.
Old Oct 3, 2013 | 11:25 AM
Carbotech Adam
Supporting Vendor
Carbotech Performance Brakes™, the world leader in Ceramic friction materials™. It was over eight years ago that Carbotech started building brake pads out of Ceramic, Kevlar, and Carbon for street, autocross and racing applications. Carbotech is the only brake pad manufacturer in the world with a complete line of Ceramic compounds for street, autocross, and track use. Carbotech-Ceramic™ compounds are known for their unsurpassed release & modulation, while maintaining very consistent torque control characteristics. Carbotech brake pads are extremely rotor friendly and contain 100% non-corrosive brake dust, that’s something that has been unmatched by any other brake pad in the industry.
Old Oct 3, 2013 | 11:35 AM
restoman1's Avatar
restoman1
Just go down to your local auto parts store and get the standard organic pads. They're readily available, cheap (around $14 a set) and will last from several months to a few years (depending on how much you drive). Yes, you'll get brake dust, but it comes right off when you wash your car.
For a stock, street driven car, you don't need anything fancy.
Ed
Old Oct 3, 2013 | 11:36 AM
ddawson's Avatar
ddawson
I've used the Carbotech 1521 on many car and is my favorite pad. At this time the C3 is using Hawk HPS Performance as I needed them fast.
Old Oct 3, 2013 | 11:42 AM
Peterbuilt's Avatar
Peterbuilt
Ed
True!
Old Oct 3, 2013 | 01:00 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Mike Ward
...Organic...
...organic pads...For a stock, street driven car, you don't need anything fancy...
Originally Posted by petes74ttop
...True!...
To Witch brake pads?
