True or False?
Old Oct 3, 2013 | 08:58 AM
CAMS69's Avatar
CAMS69
Default True or False?
Statement in regards to the pinion on a c3 diff out of the car.
"First: grab hold of the pinion yoke and try to move it up and down and in and out. If you have any play at all you have bad pinion bearings. A little slack when turning it back and forth is normal."
" A little slack when turning it back and forth is normal."
True or false?
Old Oct 3, 2013 | 09:14 AM
Mike Ward's Avatar
Mike Ward
True.
Old Oct 3, 2013 | 10:39 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I would like to buy a vowel, please.
To True or False?
