Speedometer question
Old Jul 3, 2002 | 08:36 PM
jlsru's Avatar
jlsru
Cruise-In V Veteran
Default Speedometer question
The speedometer in my 75 is not working properly.It seems to be about 10 miles per off for example if i am going 55 mph the speedometer will read 45 mph.I am running stock size tires on the vette.I have heard changing the rear end gear can cause this but I do not know if this is true.I do not know if a previous owner changed gears.Any suggestions.
Old Jul 3, 2002 | 08:53 PM
Ben Taylor's Avatar
Ben Taylor
Default Re: Speedometer question (jlsru75)
Tires, Rear end and Transmission can all change your speedo operation. You need to find out which of these is different from stock.
