I painted each part as I built the engine.
I don't like to paint over gaskets, looks much better. Just be sure to tape off areas that are not to be painted.
Powder coating a block is a waste of money to me. You really don't see much of the block unless you have a high dollar show car that your not going to drive.
powder coating ia by far a much better, more permanent, and withstands the elements much better than any spray paint. i race my vette, so not a show car per-say... but I do like a clean looking block and engine bay. So, other than money and looks, which are both a matter of perspective, is there any reason not to powder coat a block, over a fizz can???
the best way to prepare metal for powder coating is to media blast. I've never been a fan of sand in an engine , cleaning is a pain. that said it handles heat well stays glossy . run some sandpaper discs over it some light plastic filler then a good quality paint is what the show guys use
also paint before you install freeze plugs if you can, it looks sharp with the brass showing.
I've never done things the easy way! I usually take some grease and thin it with a little oil. Not too thin, then carefully "paint" the freeze plugs or any small detail you don't want coverd with engine paint. After shooting the engine and allowing it to cure, simply wipe away the grease and the part looks like new.
Not the best pic but it shows one of the plugs done this way:
You should be able to Powder Coat about anything but I'm not so sure You would want to do a Block. A Powder Coater will Heat the Part to about 400 degs . They use a special Tape for this that can take the Heat. It would take them a long time to get the block up to temp and it might throw there time schedule off for the rest of the parts they are doing. 400 degs probably isn't going to hurt a Block but if it was me I would finish machine the Cylinders after the Coating was done. So now we are Machining after Painting and the resulting damage to the Paint is bound to happen. I say Trailer Queen yes Race Car no.
the blocks machine work is complete, I use powder coat on many things and it is by far, a much superior product over paint. but to 400* worries me, i do not know enough about metallurgy, to know if this in some way, would damage the blocks makeup. I do not believe so, but I've seen heads warp due to cooling issues... what temp that happens at, I don't know,,,, but i would believe it would be much higher. and then of course there is the temper of the metal.... maybe ill call Dart about this...
