Gary- what is an 049 or 781? Skunk - no offense taken. Thanks for putting your ho out there. Only way I am gonna learn! Gerry, dochp, and Tim- thanks for sharing the info on the diff on these things! Never heard that kinda stuff before!
Different Gary, but same info: 781 and 049 are the last 3 digits of the casting number of open chamber oval port heads. Best place to start for a street engine.
They have great flow and velocity and have stock height exhaust ports, so there's no guessing about header fitment. That combined with a true high performance dual plane intake and a cam similar to the one in my sig, and you'll have a very potent engine that's also truly streetable. If you go that route, plan on putting drag radials out back.
What he said - mine is 489 with the RR oval heads - Edelbrock air gap and 950 dp - 235/242@ .050 and 2 1/8" headers - easy dyno'd 528/568 hp/tq - pulls clean from 1100/1200 rpm all the way up to 6000rpm +
The open chamber heads are better than the closed? I thought the closed would be better and give better compression. My current heads are 772s which are open. Supposedly this engine has been gone through and built up, but I know I will have to take it apart to find out how the is defined.
Open vs. closed preference really should be determined by what pistons you have. If your engine was built for open chamber heads you'll probably want to stay with that design. However, you won't know for sure unless you can determine what's currently in the holes.
How much diff between the single plane and dual plane intakes?
That really depends on the engine. First step is what do you have on hand? A complete 427 or just a block, that can help you decide where to take the build. The only trouble free performance upgrade is cubic inches most times. If it's just a block consider a 496, it'll cost the almost same in the end.
Badrad - I have the complete engine, but can do anything I want as it is sitting on engine stand and have time before it goes back on.
A complete engine is different since you have a crank and rods that are assumed good. 427 pistons are getting harder to find on the shelf and fairly expensive usually. If you have oval port heads that's a great start to a strong street engine. It all comes down to how much are you willing to invest into it? I would start with a solid plan of what you want out of the car and then focus your build around that.
I didn't have those in mind! MOre concerned about the kids in the area and my buddys with their 5.0 Stangs. Not even gonna try and take those on! Looking good though. And btw my current dd is 91 Z28!
Also as my engine is a tall deck, I will either have to have spacers or go with a limited choice on aluminum intakes that are made to fit without the spacers. Anybody here have any experience with either choice? Give me the good, bad and ugly.
There might be issues getting that in a Corvette. I've never seen a tall block dual plane intake, most guys throw big strokes in these for racing.
A tall deck is going to make it really tight getting headers in there. If it's a tall deck, someone must have already done a performance rebuild- the tall decks had 4 ring pistons and were meant to be low RPM high torque engines. Both the 366 and 427 were used in C-60 and C-70 trucks.
I've worked a bunch of the 427's in trucks with a 5+4 trans and 4.11 tandem rear axles. On 10.00x20 tires. Drop 23 tons of rock on there and get busy. 20 forward gears and 4 in reverse.
Was thinking of going with standard manifolds for the exhaust. No leaks, no blown gaskets. The family that I got engine from said the son (now in jail, needed money for lawyer) put a bunch of money in engine and had it built up for performance. Had it in a pickup and rolled it (part of going to jail I understand) but is still running. Does have an Accell Super Coil HEI distrib (and MSD wires) so it is not stock. Supposedly has been cammed (I presume I can check that by removing timing chain cover and read cam) and had other work done to it. Much to check into.
