Is a PCV Valve Really Necessary?
Old Oct 8, 2013 | 04:34 PM
v2racing's Avatar
v2racing
I have always run a PCV valve on all my hot rods. I have one on the 406 in my signature. This engine was in my 80 Vette for a few thousand miles and the intake looks just as clean inside as when I put it on, just as clean as George's (Gkull), if not cleaner. The hose between the PCV valve and the vacuum port is clean and dry inside. If it is full of oil you have something wrong in the way the PVC is installed or the engine has excessive blow-by. I see no downside to running a PVC valve. There has not been an car produced since the 60's that did not vent the crankcase to the intake, even the 200 plus MPH supercars!
I am not a greeny or tree hugger by any means, but I see no reason to pollute the air more than necessary. I too cannot stand the smell of crankcase fumes and they are detrimental to your health!
Old Oct 8, 2013 | 08:58 PM
Super6's Avatar
Super6
Originally Posted by MIKE80
I currently have an electric vacuum pump for my brake booster. I will be replacing the vacuum booster with a hydroboost setup at some point. So, I've been toying around with the idea of adding an air/ oil separator maybe something like this http://www.jegs.com/i/JEGS+Performan...52206/10002/-1. Since I won't be using the vacuum pump for the brakes, I was thinking of connecting it to the air/ oil separator to kick in at WOT. Also keep the hose going back to the carb T'd into the vacuum pump line with a check valves so it will still function during normal driving. It will be a while before I'm ready for the hydroboost, so I'll probably just pick up the air/ oil separator for now. Any thoughts on the electric vacuum pump idea?
With regard to the oil separator you linked to, the guts of it maybe exactly like the more expensive Moroso that I have, but mine came with a hefty aluminum mount that grips the separator body and another bracket for mounting it to the cylinder head. I don't have a milling machine and I couldn't make a mount and bracket that works and looks right like the Moroso unit for the $60 difference in price. Functionally, they may do the same.
I'm no expert on this but I think WOT is a condition where there isn't enough vacuum to keep the PCV closed and there is high crank case pressure to be vented. So the pressure is bled off into the intake through the PCV valve. If during WOT, you apply the vacuum from the pump to the PCV, the valve will stay closed when it needs to open and the pressure will try to bled out through some other path, like the rear main seal or at the corners of the intake or pan or out the breather and on to the valve cover. You would need another check valve to keep the pump from pulling an air/fuel mixture out of the intake at WOT. Could get pretty interesting.
Old Oct 8, 2013 | 09:05 PM
mrvette's Avatar
mrvette
Originally Posted by roscobbc
What he said - probably the reason for the hair 'style' on his signature photo!
DAMN STRAIGHT!!!!! that was a school play wig my wife's grand daughter run up and flopped on my head and so I asked for a pix.....
and so it lives on.....
Old Oct 8, 2013 | 09:20 PM
'75's Avatar
'75
That's a nice head of hair for a man of your advanced years, Ahem, experience.
Old Oct 8, 2013 | 09:30 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
This ^^^...pre pcv era cars had road draft drain tubes that would drip oil out which was forced out by excess crankcase pressure.
The first two paragraphs here should tell you everything you need to know about why you should always run a pcv system.
http://en.wikipedia.org/wiki/Crankcase_ventilation_system
Old Oct 8, 2013 | 09:34 PM
Super6's Avatar
Super6
Anyone that wants it to work the way it was intended should not use a breather on the valve cover. The non-PCV-valve-equipped valve cover should be plumbed to the air cleaner (as from the factory), because at WOT the PCV is so ineffective due to the lack of vacuum, that the blowby just goes out the breather or up the hose to the air filter and gets burned (with some of the result being the problem of oil in the intake that we don't want). Nothing is vented to the atmosphere if the air filter is used as the breather. This explains why you occasionally might see an oil droplet on the coarse screen in the air cleaner base with the hose hooked up.
Old Oct 9, 2013 | 08:29 AM
commander_47's Avatar
commander_47
The PCV system is one of the only things to come out of the early smog cars that is worth using.
It is totally beneficial to your engine. It will clean and filter nasty crankcase gas and run fresh air through it.
Clean air is pulled through the PCV into the crankcase from the top of the air filter.
It should exit the other valve cover through a filter and via vacuum back into the base of the carb.
If you are using a filter, the nastiest gunk doesn't go back into your motor. And anyway, what is pulled in via the carb is reburnt.
A win win for the environment and your motor.
An open system doesn't use the vacuum of the carb to pull the fresh air through. It just vents to the engine compartment spraying a fine mist of gunk all over everthing. Also, since it isn't controlled by vacuum, a lot of crap stays in the engine.
Just putting vents in the valve covers equalizes pressure without any beneficial cleaning; other than what the spinning crank might pull into the motor.
Old Oct 9, 2013 | 08:56 AM
KJL's Avatar
KJL
Because my engine is not stock, what size PCV valve should be used? Will just a plain old unit for a stock 350 work?
Old Oct 9, 2013 | 10:07 AM
gkull's Avatar
gkull
Crankcase ventilation system - Wikipedia, the free encyclopedia
You didn't even read your own Wikipedia to the end.
Not all petrol engines have PCV valves. Engines not subject to emission controls, such as certain off-road engines
I've never noticed oil, or bad smells, I also run 192 - 195 stats and try and keep the heat up to make the engine more efficient. Higher operating temps also keep water out of the oil.
I think what it really comes down to is: does recirculating burnt gasses back through the intake increase HP or does fresh 100% outside air have higher HP?
As for me I need to spend some money on the Vette so I am installing a vacuum pump this winter and gaining HP
Old Oct 9, 2013 | 11:08 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
A properly functioning PCV system will have no impact on performance,..end of sentence.
Old Oct 9, 2013 | 11:48 AM
Surfer69's Avatar
Surfer69
Mine is a daily driver with two breathers. When rings didnt seat properly the breathers dripped oil. When new rings seated correctly breathers never dripped and stay white almost a year.
Never smelled any crankcase odors so not sure why people say that. Engine compartment is always clean, no mist. .02
Old Oct 9, 2013 | 02:47 PM
gkull's Avatar
gkull
Do you honestly believe that under highest vacuum conditions like steady state going down the freeway at 65 MPH and a vaccuum gauge reading 18 inches and you have a 3/8th inch PCV hose that your motor is not injesting a higher % of junk air? It is like the exhaust gas recuiculation systems of yesteryears. Yes, it does slow down the burn rate of the new incoming A/F and reduce combustion temp.......... more clean air out the pipe at as great loss of MPG directly related to the corresponding loss of HP
