camshaft removal
Oct 8, 2013 | 12:32 PM
camshaft removal
Guys;
Need to replace my camshaft and was wondering if the rad can stay in car?
Thanx Wadey
Oct 8, 2013 | 01:04 PM
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
If you can remove the cam without removing the radiator, please take a video of it. This will be good !
Oct 8, 2013 | 01:54 PM
No, it needs to come out.
Oct 8, 2013 | 03:32 PM
Some say it can stay and you might be able to do it. I personally took the radiator and shroud out.
Oct 8, 2013 | 03:39 PM
Take radiator and shroud off. Pull A/C forward out of the way. Only then will you have the room.
Oct 8, 2013 | 03:50 PM
I have changed the cam in my '69 when it had the small block without removing the radiator.
Oct 8, 2013 | 04:05 PM
Yes.
If you remove the engine from the car.
Oct 8, 2013 | 06:18 PM
St. Jude Donor '12
My 77 had to remove the rad, The A/C rad. I was able to swing it up out of the way, and leave the A/C hoses connected.
Oct 8, 2013 | 10:51 PM
I've done it with the radiator in, however you really have to play with positioning it and you would want to put some cardboard or masonite on the radiator fins . not to protect the fins as much as to save your hands. it isn't that much more to pull the radiator and most people will find it easier.
