Electric problem on my 1970 corvette
Old Oct 9, 2013 | 07:02 PM
egon48's Avatar
egon48
Default Electric problem on my 1970 corvette
My amp gauge goes from center pointer to minus every time the directionals are used,when i use the brakes ,headlights and when i put on the a/c it moves alot at idle or driving.I installed a 100 amp alternator ,this helped it a little ,the needle moved less .I bought a new battery ,cleaned all the body to chassis grounds,nothing helped,anybody have any ideas on how i can fix this problem?
Old Oct 9, 2013 | 08:43 PM
1974ta's Avatar
1974ta
Default Ground
Most problems of this sort are caused by grounding issues. Check to make sure all the grounds are connected and making good contact. There are grounds behind the dash, under the center console and all over the car since the body is fiberglass.
An AIM will show you where all the grounds are located.
Bill
Old Oct 9, 2013 | 09:18 PM
lionelhutz's Avatar
lionelhutz
Did you happen to run a new wire from the alternator to the starter solenoid? I'm thinking the gauge is no longer measuring any charging current so it just shows the discharge caused by running electrical loads.
Old Oct 11, 2013 | 04:40 PM
egon48's Avatar
egon48
Iam changing some relays and cleaning all the ground points and connectors ,see what happens when i connect the battery again?
To Electric problem on my 1970 corvette
