Differential drain plug in an '80?
Old Oct 10, 2013 | 08:32 AM
Teem66's Avatar
Teem66
Default Differential drain plug in an '80?
1980 L48 Auto
Anyone put a bottom drain plug in an '80 or other MY differential with an aluminum case? I was all set to do the job when I saw a comment that because the case on my car was made of aluminum the plug would strip the threads over time. Anyone had this problem? After all, there is already a drain plug in the differential (just in a PIA location).
Old Oct 10, 2013 | 10:53 AM
Gale Banks 80''s Avatar
Gale Banks 80'
Originally Posted by Teem66
1980 L48 Auto
Its been done many times. There has been more Corvettes built with Aluminum cases than Iron and yet people are still afraid of them. I suppose we could go back to Iron Transmission cases to keep them from stripping out to.
Old Oct 10, 2013 | 01:20 PM
Street Rat's Avatar
Street Rat
Tracdogg2 put a drain plug in the bottom of my differential when he rebuilt it. Very handy.
Old Oct 10, 2013 | 01:47 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...After all, there is already a drain plug in the differential (just in a PIA location)...
Not quite. That's a fill plug, not a drain plug.
Old Oct 11, 2013 | 01:14 AM
Teem66's Avatar
Teem66
You'll never make it in the septic tank cleaning business (the "drain" is on top).
Old Oct 11, 2013 | 01:57 PM
tracdogg2's Avatar
tracdogg2
There's no problem putting a drain plug in a dana diff. But it does have to be in a certain location.
Mike
Old Oct 11, 2013 | 09:10 PM
garygnu's Avatar
garygnu
you will probably change the fluid every 30k ,so you won't be loosening and tightening alot .just don't over torque it .start with a small threaded plug.use sealant on it .
Old Oct 11, 2013 | 10:58 PM
lvmyvt76's Avatar
lvmyvt76
do you strip out the oil drain plug when you change the oil???? You will change the dif- lube a lot less time that oil!
Old Oct 12, 2013 | 04:24 PM
Teem66's Avatar
Teem66
Apples to Oranges. The oil pan is steel the differential is aluminum.
Old Oct 13, 2013 | 05:50 PM
bschuus's Avatar
bschuus
I have been thinking about doing this. Where about would the drain plug go?
Old Oct 13, 2013 | 09:06 PM
Teem66's Avatar
Teem66
One of the usual suppliers has a kit that has a template for drilling the hole. Sorry I forgot which one.
Old Oct 13, 2013 | 10:03 PM
bschuus's Avatar
bschuus
Great I'll check it out. Thanks
Old Oct 14, 2013 | 09:03 AM
Teem66's Avatar
Teem66
I just talked to Gus at Corvette Central and he said that their differential drain plug kit will not work on a 1980 differential because it is aluminum. They list the kit as working on 1963 to 1979 MYs.
To Differential drain plug in an '80?
