l48 rebuild
are the heads worth even rebuilding, I can get a set of 305 vortecs for 200. but they will need a going over. and a vtech performer for 125
and (opening can of worms) can anyone recommend a cam
all stock 73 350/4speed 3.55gear
What is a crank kit.... a 383?
Why are you installing flat top pistons? Low compression is one of the problems an L-48 already has. It also has small valve heads and a slug of a cam.
If you're going to build an engine, up the compression to 10.0-10.5/1 and install big valve heads 2.02/1.60. Your choice of heads and compression will help decide which cam to use.
If you build the engine to L-82 specs, but with 10.0-10.5/1 compression, you'll be in the 350hp (gross) range.
http://www.superchevy.com/technical/..._dyno_testing/
OP, do you have the 882 heads? You would be best to upgrade to a 64cc cylinder head.
http://www.speedwaymotors.com/Flo-Te...lug,25118.html
And this cam kit:
http://www.summitracing.com/parts/su...make/chevrolet
The Flotek heads have a very favorable intake/exhaust ratio, so a straight grind cam should work well.
There are better heads and cams out there, but you're gonna pay for them.
Scott
what ever head is stock.
flat tops cause I already have set hung on rebiult rods.
just a weekend driver, far from a racecar.
crank kit is just a stock reconditioned crank. kit is only 125.oo, I have all gaskets already.
If you're diving in that deep, it's worth it to go the extra $5-600 to have the block boiled, bored, honed to the pistons you are using!
Question; are you experiencing any knocking or low oil pressure problems?
If not, go with the heads to wake her up.
If you are, a 383 kit is the best bang for the buck
looking at these parts.
350, stock bore, flat tops. stock vortec heads, performer intake. stock Q-jet.
4 speed, and 3.55. headers and side pipes
need a cam though , recommendations ? flat tapped hyd or solid
As stated above, the block should be boiled, bored, honed to your new pistons. What will your compression be with flat tops installed? Big heads, big cam, and low compression isn't the best combination.
You may want to rethink or wait till you have a bigger budget. No point in tearing the engine apart and getting less than stellar results. It sounds like you would be better off buying a crate engine to drop in.
interesting article, 10 to 1 with a heavy truck might cause donation, but in a vette where would we be.
maybe back the timing down a few degrees,
what about a cam with some over lap to bleed off some cylinder pressure?
With the way you are going about this rebuild I doubt you'll have a true static 10.0/1 compression (and dynamic will be even less). What is your deck height, thickness of head gaskets, etc., etc.?
TCT
Over several years, starting with purchasing a good set of heads that were used on the stock L-48 set up, I added other parts, incrementally. After 3 years I had a stroker!
Except for the heads, headers, and intake, and carb, which came from the L-48, my budget allowed me to build what I wanted.
What I built was:
383 stroker
'0' deck block
Hyper cast pistons with 12cc dish
Built using a 4 bolt bottom end
10.4 static CR - runs on mid-grade fuel with no problems @51* total timing. Basic timing all in by 2400 rpm
CC XE274H cam
There are many ways (parts) that can be used to get your desired results, but you have to know what you want, to match the parts.
