427/430 rebuild/dyno
Old Jul 5, 2002 | 12:28 AM
Justin1984's Avatar
Justin1984
Default 427/430 rebuild/dyno
Howdy folks. I remember reading recently about a 427/430 being rebuilt to factory spec and dyno'd. The results were something like 515hp and 525 lbs ft torque. Was that an article in a magazine or was it somebody's post here on the Forum? Could you link the info?
Old Jul 5, 2002 | 01:52 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: 427/430 rebuild/dyno (Justin1984)
I remember this post. It was about a engine built to L-88 specs. L-88's were intentionally underrated by GM.. The actual output was anywhere from 500 - 580 HP...
:cheers:
Olivier
Old Jul 5, 2002 | 06:52 PM
SBR's Avatar
SBR
Default Re: 427/430 rebuild/dyno (GrandSportC3)
It was a forum members car a 69L88. It was built to stock specs and dynoed at 465hp with the stock manifolds and 540hp with open headers. BTW the car was running a slightly lower compression ratio and a larger flywheel so I believe I would have put out another 25hp.
To 427/430 rebuild/dyno
