Lm1 350 crate compatible transmission?
Old Oct 16, 2013 | 02:19 PM
Tsunami_Vette's Avatar
Tsunami_Vette
Default Lm1 350 crate compatible transmission?
Hi All,
I've searched a lot about this but I'm not sure what the right choice is. I am the second owner of an '81 vette, the original owner was a little old lady (I'm serious!). I think a shop may have conned her and convinced her to put a new motor in it...whatever the case was they put a LM1 350 crate in it. The vette still has the original 3 speed automatic which I absolutely loathed. So my question is what kind of manual transmission, preferably a 4 or 5 speed w/overdrive, is compatible with the LM1 350? Will I need a new rear end as well or is it as simple as a tranny swap? Thanks for any help!
Old Oct 16, 2013 | 02:47 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
The LM1 is basically the same as an L-48. My '80 Z/28 had an LM1 in it. It's a common small block like any other. Any transmission setup that fits an internally balanced GM engine of the same generation will work if you change all the right parts. You rear gear may be a little high for a manual trans for the best performance but it will work as long as you don't abuse it too much. It is either a 3.07 or a 2.87 if I remember correctly.
Old Oct 16, 2013 | 02:51 PM
Tsunami_Vette
thanks for the info CaseyJones...much appreciated!
Old Oct 16, 2013 | 02:57 PM
Tsunami_Vette
from my research it appears the stock rear end for the automatic for the '81 is a 2.87. I don't plan on abusing it much...well maybe a just little haha
To Lm1 350 crate compatible transmission?
