Do I have ann M-21????
Old Jul 5, 2002 | 04:04 PM
68350hp's Avatar
68350hp
Default Do I have ann M-21????
My car shifts very rough and has the short throw shift linkage. I don't think it has an M-20. It there a number I can see on the trans without having to jack up the car?
Old Jul 5, 2002 | 04:42 PM
BB wowbagger's Avatar
BB wowbagger
Default Re: Do I have ann M-21???? (68350hp)
The only way to id you trans is to put the car on stands and crawl under it.Theres a nr on the passenger side of the tranny. :smash:
Old Jul 5, 2002 | 04:54 PM
Darkness's Avatar
Darkness
Default Re: Do I have ann M-21???? (BB wowbagger)
check your build sheet, or someone here will be able to tell you that just by the VIN.
Paul
Old Jul 5, 2002 | 05:33 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: Do I have ann M-21???? (inferno-vette)
You can't tell by the VIN on a 68. I read my numbers by lifting the front end just enough for me to get under it.... As mentioned above it will be stamped on passenger side of tranny. Post numbers here and someone will decode it for you.
Old Jul 5, 2002 | 06:01 PM
PRNDL's Avatar
PRNDL
Default Re: Do I have ann M-21???? (71,454,4spd)
A simple road test will tell you if you have M20 (wide ratio) or M21 (close ratio)
Both transmissions have a 1:1 4th gear.
3rd gear is 1:28 on the M21
3rd gear is 1.46 on the M20.
Drive your car in 4th gear and get rpm to 2000.
Keeping speed constant, downshift to 3rd gear.
If rpm jump to 2560 (1.28 * 2000) you have M21
If rpm jump to 2920 (1.46 * 2000) you have M20.
Try it! :) MJ
Old Jul 6, 2002 | 04:52 AM
BB wowbagger
Default Re: Do I have ann M-21???? (MNJack)
Well,thats depends on the rearend gearing also...Or am i wrong? :cheers:
Old Jul 6, 2002 | 05:06 AM
FinnShark's Avatar
FinnShark
Rearend ratio doesn't effect to that. Rearend does effect to the speed you are travelling, but it doesn't effect to the rpm's.
Old Jul 6, 2002 | 10:03 AM
Flareside's Avatar
Flareside
One more thing that nobody has mentioned: There is no external number or stamp on a '68 Muncie that will tell you what model you have (M20, M21, M22). '69 and later have an A, B, or C stamped into the case that indicate the model. Not so for '68.
Mine's an M21, but I wish it were an M20 :D
Old Jul 7, 2002 | 09:32 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Default Re: Do I have ann M-21???? (Flareside)
You can tell the difference just by driving one. An M-21 will drop 350-400rpms in between shifts were as the "wider" ratio trans will "drop" like 550-600rpms in between shifts. My '68 has the M-21 and my '80 the "wide ratio" trans and it is easily detected just by driving either car.
Old Jul 7, 2002 | 05:50 PM
69L71's Avatar
69L71
According to Vette Vues Fact book on the 69-72 Stingray, by Dobbins (which is NOT always right BTW), '68 base motor (300HP) corvettes were only available with the M20. Also, small block corvettes only got M21s with 3.70 or 4.11 gears, and that was only the 350HP version in '68. If you believe your car is mostly original, you can be assured is not an M21.
M20s have a 2.52:1 1st gear ratio and the M21 has a 2.20:1
Old Jul 8, 2002 | 01:05 AM
theandies's Avatar
theandies
Default Re: Do I have ann M-21???? (69L71)
Get the number off the side of the tranny and go here to decode it. http://www.5speeds.com/index.html
navigate to Muncie 4-speeds in the left pane and enjoy.
John
Old Jul 8, 2002 | 02:36 AM
Paul 73 Coupe's Avatar
Paul 73 Coupe
Default Re: Do I have ann M-21???? (theandies)
Casting: 3925661 Years: 1970 - 1974 Ratios: M20 2.52 1st , M21 2.20 1st, M22 2.20 1st
woohoo...I wasnt sure I had the stock trans. :cool: :cool: :cool:
[Modified by Paul 73 Coupe, 12:36 AM 7/8/2002]
To Do I have ann M-21????
