1.6 rockers??
Old Jul 5, 2002 | 07:59 PM
Chris Tabor's Avatar
Chris Tabor
Default 1.6 rockers??
Will 1.6 rockers work or fit ok on my 73 L48? I don't know much about motors so any help would be great.
Old Jul 5, 2002 | 08:29 PM
1979toy's Avatar
1979toy
Default Re: 1.6 rockers?? (Chris Tabor)
No. At a minimun, the pushrod holes in the head will have to be opened up.
Old Jul 5, 2002 | 09:01 PM
Corellian Corvette's Avatar
Corellian Corvette
Default Re: 1.6 rockers?? (1979toy)
Not true.
I have Comp Cams 1.6 roller-tip rockers on my stock '73 L-48 and they work great.
If your heads have vertical oval ports for the pushrods you won't have a problem.
Now, if you want to use the stock valve covers, you can't use the full 1.6 roller rockers w/o a thicker gasket or aftermarket covers. The 1.6 roller tip rockers fit fine, but you don't gain the advantage of the friction loss that full roller-rockers provide.
I was very pleased with the SOTP improvement vs. the cost and installation time.
Old Jul 7, 2002 | 06:14 PM
Chris Tabor
Any other info???
To 1.6 rockers??
