need part numbers
Old Oct 27, 2013 | 06:26 AM
ballen06's Avatar
ballen06
Default need part numbers
Could someone please tell me what the proper U Joint part numbers are for my corvette.
I'm interested in Spicer or AC Delco U Joints..
I need half shaft and drive shaft joints..
I have a 1969 350/350 corvette.
Thanks in advance.
Old Oct 27, 2013 | 11:52 AM
lvmyvt76's Avatar
lvmyvt76
any parts house with a good parts guy should be able to tell you, you need to decide if you want to grease them or not, they have them both ways, the un-greaseable are stronger(usually). Then you can go to stronger ones also.
Old Oct 27, 2013 | 12:35 PM
Scott Marzahl's Avatar
Scott Marzahl
http://www.dennysdriveshaft.com/c37_u_joints.html
Old Oct 27, 2013 | 02:01 PM
Solid LT1's Avatar
Solid LT1
If your 69 is original with 4 speed manual trans as installed by GM this is the part you want: http://www.dennysdriveshaft.com/p307...oint_1310.html
Old Oct 28, 2013 | 05:39 AM
ballen06's Avatar
ballen06
That's what I need ... Thanks all .. much appreciated..
To need part numbers
